Results 1 to 6 of 6
Thread: Vr FE2 change over
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Default Vr FE2 change over
    Hey there. I'm planning on changing over the standard suspension in my vr for the fe2.
    Anyone know where I can get a kit? eBay really the only place? Anyone here selling a kit?
    What's needed too? Just front and rear springs and the struts? I'll be replacing the shocks with newies anyway. So a kit without doesn't really bother me.
    Quote Originally Posted by PaRaDoX View Post
    btw do you plan to fly? looks like you have a gauge for everything, refreshment levels gauge, washer fluid temp? penis pump vacuum? *runs and hides*
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Why is "power" so important? Do you have a little dick?
    People are too obsessed with how much "power" their car makes....it doesn't make power, it produces torque, from which this mythical "power" figure is calculated.
    wraith's Avatar
    wraith is online now Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Talk to GSL rally sport. King lows are the same height. FE2 isn't that much different from stock you know.
    VR Commodore V6
    Sep 2008
    Sydney NSW
    But what are they like? Are they a really good spring?
    If I do go down that path, I'd probably end up just going about 1.5" lower max. Would I still be able to use the standard strut, or does that need to be replaced as well? Or is that just the case with any spring replacement?
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    You can use the standard front struts with FE2 springs, but the standard rear shocks are too long and the springs wont be fully captive without shortened shocks.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    VR Commodore V6
    Sep 2008
    Sydney NSW
    I wasn't gonna particularly keep the standard shocks anyway. Haven't tested them, but I'm sure they've seen better days.
    VS Acclaim
    Jul 2011
    NSW
    VS COMMODORE LOWERED KING SPRINGS & MONROE GT SHOCKS | eBay
    Check this ebay listing out for an idea. They claim it is only 10mm lower then fe2 and 30mm lower then standard.
    Also you should have better handling if you also replace your standard shocks
  1. Oil Change....
    By Kikki in forum Jokes/Humour
    Last Post: 26-08-2011, 10:54 PM
  2. change ecu.. change memcal..?? fault finding
    By bandit10 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-02-2010, 08:29 PM
  3. Oil Change
    By batty_123 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-10-2008, 12:17 AM
  4. Oil Change/filter change interval on VTII 6 cyl ?
    By nmldb in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-06-2006, 04:26 PM
  5. Considering a change...
    By fourstar82 in forum General
    Last Post: 05-07-2005, 11:22 PM
