Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By nemesis_adrasteia
Thread: Inlet manifold gasket
    spud_22's Avatar
    spud_22 is offline Ruled by the P
    95 VS Berlina
    Nov 2010
    Default Inlet manifold gasket
    So i lost a full reservoir of coolant today. It sound like the engine is missing too when i give it a tap of the accelerator. when it makes the mising noise water spurts out the exhaust. Could this be the manifold gasket or a head gasket?
    Cheers guys
    3.08 LSD, 1.9.1 High Ratio Rockers, MACE CAI, Spacers
    spud_22's Avatar
    95 VS Berlina
    Nov 2010
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Define 'lost' ?
    The reservoir isn't a clear indication of your coolant levels, in fact it varies a lot. It fills/empties as is needed by the coolant system. (someone correct me if i'm wrong)
    Check your radiator for the correct indication of coolant levels
    spud_22's Avatar
    95 VS Berlina
    Nov 2010
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Quote Originally Posted by spud_22 View Post
    Just gone. radiator is full.
    Wouldn't stress unless the radiator level drops or you experience overheating issues.
    spud_22's Avatar
    95 VS Berlina
    Nov 2010
    Yea but it is missing and water is coming out of the exhaust. thats what im stressing about.
    Thanks for helping too
    elmaso's Avatar
    elmaso is offline PARTY AND BULLSHIT!
    VR Calais
    Jul 2010
    that doesn't seem like a manifold gasket, mine was faa-aarked and it made it from narre warren to geelong pretty fine, a little moister out the exhaust on start, but that was it, if it was your head gasket it would be overheating every so often and steam would be pouring out every where, happened to my mates VP calais.
    spud_22's Avatar
    95 VS Berlina
    Nov 2010
    Yea not over heating. But i havent been driving since i think it happened. I think im just going to replace the inlet manifold gaskets if i can see that there f*&^ed ill just change them but if they look ok ill change the head gasket as well.
    elmaso's Avatar
    VR Calais
    Jul 2010
    do an error check, see if theres anything else would be apart of the problem, then try a mechanic.
    just remember its a fair bit of work to get a new gasket under the head.
    nemesis_adrasteia's Avatar
    nemesis_adrasteia is offline better to reign in hell
    VR accliam, TF gemini, TC gemini, 79 isuzu ute
    Feb 2009
    longford, victoria
    get it pressure tested and also tested for combustion leakage.
    "The mind is its own place, and in itself, can make a Heaven of Hell, a Hell of Heaven."
    apparently wasting my time with 97 cubic inches
    milk doesnt come in 1.6 litres
    my geminis
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by elmaso View Post
    Had a case here that was claimed to be a blown head because it was overheating, but it turned out to be the themostat was not working.
    VY SS
    May 2011
    Auckland
    Def try to diagnose where this water is coming from. Have you checked all of the coolant pipes, isn't there a small one coming off the back of the engine for the heater?
    A head gasket is a big job, not to be undertaken unless absolutely necessary.
    spud_22's Avatar
    95 VS Berlina
    Nov 2010
    So there is a spare ecotec engine sitting at home. I pulled everything off down to the heads to see how hard it is to change. Really dont want to change the head gasket now. I cant see how water is getting into the missing cylinder tho. From looking at the spare engine water would have to go through and oil chamber to get to the cylinder. Im just going to have a look at the inlet manifold and if its not that its of to the mechanic to fix.
    Thans for all the info guys
    jesse_lankey is offline what to put here?
    VS S3 Ute
    Jan 2010
    check your oil, if its milky then theres a good chance the inlet manifold gasket has gone, thats what happened with my ecotec
  15. #15
    vs commodore
    Oct 2009
    Tamworth NSW
    When my inlet manifold gasket on my VSV6 was blown, it was using around a litre of coolant every day or two, it was pumping heaps of coolant straight out of the exhaust. It didnt overheat at all though when I drove it and it didnt run too badly once it had been running for a minute or two . It was like this for about about two weeks, then the engine oil started to get emulsified with coolant and it started to get the milky look about it, so I removed the inlet manifold and confirmed that the inlet manifold gasket was blown out near the water jacket in the head, and coolant was leaking straight out of the coolant passage, and straight into the inlet runner of the rear cylinder on the passenger side.. I bought a VRS kit (Valve Regrind gasket Set) , which also came with new head gaskets, so I removed the heads a while I was at it, just to check them out and to give the heads, the valves and piston tops a cleanup. The engine was supposed to be a new engine from redlands in brisbane, and after this happened, I had my doubts, even though the reciepts for the new engine came with the car. I confirmed the engine was at least recently rebored and honed etc once I had removed the heads. I noticed that all the inlet manifold bolts were only finger tight when I removed it, so this must have been the cause of the inlet manifold gasket blowing out so quickly I think. The engine had only done a few thousand K's at the time.
  16. #16
    spud_22's Avatar
    95 VS Berlina
    Nov 2010
    Quote Originally Posted by Brett_jjj View Post
    Cheers mate this sound exactly like mine same cylinder as well. So engine will be coming apart on wednesday night now.
  1. Head gasket or inlet manifold gasket? HELP!
    By CUR53VT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-11-2011, 03:54 PM
  2. inlet manifold gasket for vt v6
    By jewel_aus_88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-10-2011, 03:31 PM
  3. Inlet manifold gasket
    By hainzy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-03-2011, 01:24 PM
  4. Head Gasket? Inlet Manifold Gasket ? which one ?
    By Hydrobollox in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-04-2010, 08:11 PM
  5. inlet manifold gasket
    By gungazza in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2010, 11:33 PM
