Results 1 to 3 of 3
Thread: Knock/creaking noise in the front
    1995 vs commodore
    Oct 2011
    bribie island
    Default Knock/creaking noise in the front
    Hey past couple weeks had this creaking knocking noise in the front of my vs just had a wheel alignment done came out shitter then when it went in..I've replaced the upper control arm bushes and new link pin bush kit.. It knocks when it turn the wheel as I'm leaving the driveway or entering one or making u turn etc. just bought new set of outer tie rod ends but will get them replaced when the wheel alignment gets done.. Any other suggestions on what it could be if that doesn't fix it??
    VB SL/E
    Dec 2008
    It could be one of the Z bar (Caster rod) bushes or even the inner bush.
    Best bet to get a gregory's manual or equivalent as they show you what to check and how.
    Drawnnite's Avatar
    Drawnnite is online now Obviously Unsensible
    2000 Vs Ute
    Sep 2010
    if your talking about a grinding noise when steering at low speeds i think i know what you mean.
    i first got it after front struts were changed and a wheel allignment done.
    i had the tie rods. and front strut bearings/mounts (single unit thing) changed.
    had a wheel allignment.
    drove it and it had the same creaking/grinding noise as when it went in to get it fixed (well another thing but anyway)
    drove in this morning and could still hearing it.
    got back and drove it this arvo and it was gone.
    tie rods (about $24ea) and the mounts/bearing (about $35 ea) are pretty cheap and youll need another wheel allignment
    maybe try those and give it a few days to settle in?
    other then that im going to be no help to your cause.
    but ill be back on if it comes back tomorrow when i drive it (could be temp related if it comes back?)
    how about we make the pedals out of sticky rubber and the shoes with steel spikes. at least my shins would like that
    Quote Originally Posted by Jonesy484 View Post
    yeah i wondered the same thing when i was 4 when i grabbed the chrome exhaust of my dads rx7
    Quote Originally Posted by DM 55 WA View Post
    did you think it was a milo tin?
  1. creaking noise in front suspension
    By hoey19 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-12-2011, 11:22 PM
  2. Creaking Noise
    By MikeCuzzy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-09-2010, 09:41 PM
  3. Creaking noise at high speeds?
    By demuck in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-07-2010, 11:55 PM
  4. '99 vs statesman knock noise in front r/h
    By pjdm1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-04-2009, 10:14 AM
  5. creaking noise when turning
    By freddys in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-01-2007, 11:53 AM
