Hi, can anyone please tell me what the torque settings are for the crank shaft, flywheel and pulley, for a Holden Senator 5.7L 6 speed
ls1 or holden engine?
In that case he needs to go to the LS1 forum
Australian LS1 and Holden Forums
Wish I had a LS1 in the old VS.......
The VR had a stroked Holden V8 that was 5.7L, but from factory it was an auto. It's quite possible the OP is putting a 6 speed behind it therefore the question about the flywheel bolt torque settings.
But I'm only guessing.
Hence why i asked the original question
You could get the GTS in manual stroker thought couldn't you?
Actually just looked it up, yes, it came with a 6 speed as well.
Here you are, knock yourself out. AFAIK, the torque setting for the 5l motor were the same as for the 5.7l Holden motor:
awesome thanks heaps!
