Results 1 to 3 of 3
Thread: climate control not working? and overheating/fan problem
    Nov 2007
    Default climate control not working? and overheating/fan problem
    hey all, ive got a vs here which has had a vt motor installed. i added the extra sensor for the ecu so it runs properly .. the low fan cuts in at around 3/4 temp then when it gets just below the 3/4 turns of wich is useless as tits on a bull.. its also messing with my climate control? if the motor is to hot sometimes when i start the car the climate doesnt turn on straight away it will just cut in a minute or two later.. is this normal? this time i started the car while still being at running temp and the climate control didnt turn on at all? , as for fan problems. when the AC runs the car sits at half temp where it should and the fans work fine.. no ac on the car over heats. ive checked and replaced both relays and also checked pin f6 on the ecu and that is fine also? anyone have any idea what might be happening with this box of junk?
    Nov 2007
    oh also their is a metal pipe behind the climat econtrol unit wich gets prety damn hot?
    hako is online now Donating Member
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Can you confirm you have climate control and not garden variety A/C as fitted to Executive models?
    You may find that the fan not cutting in till 3/4 is normal - admittedly some people have the fan cut in at 1/2 or lower but like I say, many don't cut in till 3/4 (mine included). At 3/4 the engine is not overheating which will occur when the gauge reaches the top and the warning chime sounds. Commodores run hot - they are designed this way for efficiency (or so the manufacturer says).
  1. VS Climate Control not Working Urgent Help please.
    By calais_SC6 in forum Electrical Wiring / Questions
    Last Post: 08-12-2009, 06:58 PM
  2. Climate control fan not working?
    By biggls in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-11-2009, 07:49 AM
  3. Climate Control Fan Not Working On 1&2
    By DVS-50L in forum Electrical Wiring / Questions
    Last Post: 13-08-2009, 06:20 PM
  4. Climate Control Air-Con not working.
    By hsvpunk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-01-2009, 08:49 PM
  5. vs climate control not working?????
    By 308commodore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-07-2008, 08:32 PM
