Results 1 to 5 of 5
Thread: Engine Issues...
    VS Berlina/ KJ Verada
    Sep 2006
    Default Engine Issues...
    Hi guys. Can someone tell me if a leaking injector would cause a rough idle? Plus in the last month or so the L/100 has risen from 11.9 to 12.7-8 (just going off the dash readout) The rough idle just started this afternoon and as I was inspecting the engine I noticed one of the injectors was wet with fuel. I can upload a video of how it sounds if needed and someone can tell me how. Cheers.
    95 VS Berlina
    http://forums.justcommodores.com.au/...ml#post1891856
    I need some statesman/ calais woodgrain for drivers side panel!!
    ephect's Avatar
    ephect is online now Donating Member
    VS Acclaim V6
    Jul 2006
    first thing i would be doing is changing the o-rings on all the injectors.
    get your l/km from filling up and resetting your trip, more accurate
    Wombles's Avatar
    Wombles is online now Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    That injector would most likely need replacing. It would cause excessive fuel in and may even allow fuel in at the wrong time.
    I would actually try replacing the O rings, injector tops and filters first. See if it improves then.
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    It is funny.. When you had inlet manifold off I suggested you replace those o-rings
    I also replaced the filters and and pintle caps. Changeing the filters on my injectors solved my problems.
    Sep 2006
    Quote Originally Posted by James39 View Post
    Good memory! Yes you did, I should have listened.
    I'll prob just replace the injector, as in 9 years I've never serviced them or anything. I assume the best thing to do would be to just replace them all at the same time?
    Cheers for the advice guys.
    95 VS Berlina
  1. ve engine issues
    By relaxd in forum VE Holden Commodore (2006 - ?)
    Last Post: 06-06-2011, 06:43 PM
  2. VE 2007 Engine issues
    By Topgun74 in forum VE Holden Commodore (2006 - ?)
    Last Post: 16-02-2011, 04:11 PM
  3. ve omega engine issues
    By stato98 in forum VE Holden Commodore (2006 - ?)
    Last Post: 10-07-2010, 10:07 PM
  4. Engine Issues
    By me&myVZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-09-2009, 08:26 PM
  5. Engine Fan Issues
    By carlosmarlos in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-12-2006, 01:42 PM
