Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By hako
Thread: metal pipe under dash
    VS Exec S2 bt1 1996
    Apr 2011
    sydney
    Default metal pipe under dash gets very hot!
    does anyone know what the metal pipe is on the drivers side of the dash just behind the hot/cold knob and fan speed switch?mine is heating up very hot-to hot to touch and i can feel heat coming from it on my left leg while im driving!
    hako is online now Donating Member
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You must have a sensitive leg!....that pipe is the hot water pipe to the heater. If you dial COLD it should not get hot. If it still gets hot then a vacuum hose to the heater tap may have come off which leaves the hot water flow on at all times....this is not uncommon.
    Good Luck.
    VS Exec S2 bt1 1996
    Apr 2011
    sydney
    haha only one of my legs are sensitive and its not the left one!....when i felf the heat i thought that the heater was on but it wasnt the switch was in the cold position and when i turned the fan on it was cold air coming out not hot.. enough heat comes off this pipe that it heats my whole car inside and heats up the plastic molding on the side of my console aswel
    VS Berlina/ KJ Verada
    Sep 2006
    Heater tap could also be broken letting hot coolant continuously flow through the heater core. Replaced mine a while ago and stopped the same problem.
    95 VS Berlina
    http://forums.justcommodores.com.au/...ml#post1891856
    I need some statesman/ calais woodgrain for drivers side panel!!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    When you dial COLD, the switch applies vacuum to the heater tap, which then closes cutting off the supply of HOT coolant to the heater.
    I cannot figure how the pipe can be HOT when you dial COLD and have COLD air coming out when the pipe is HOT......if the pipe is HOT then the heater must be HOT and the air coming out should be HOT.
    However, I've just thought about it and BINGO - the air is cold because the airconditioning is cooling the HOT air down......so that indicates your heater tap is not turning the coolant supply to the heater off.
    To check, press the AC button OFF, dial to COLD and see if the air is HOT.....if still cold then I'm a monkey's uncle.
    VS Exec S2 bt1 1996
    Apr 2011
    sydney
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check that the dial is turning the vacuum off as per the attached pics:metal pipe under dash-heaterbutton..jpgmetal pipe under dash-hotvacswon.jpgmetal pipe under dash-hotvacswoff.jpgmetal pipe under dash-heateroff.jpgmetal pipe under dash-heateron.jpgmetal pipe under dash-heater-vacuum.jpg
    Note that in the first pic, the operating rod is not attached.
    VS_Pete_1's Avatar
    VS_Pete_1 is online now Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Thanks hako number 4&5 pics I needed to see.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    vr commodore
    Jul 2011
    south australia
    my car has a similar problem to this but it only blows hot hair, it sucks coz i wanna be in my wagon but all i eva get is hot hair
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by yoshi87 View Post
    Follow the steps above or check this: Air Conditioning Advice
    VS Exec S2 bt1 1996
    Apr 2011
    sydney
    yeh i had to unconnect the rod and pull the arm right back as far as it would go towards the back of the cold/hot dial on my console then reconnect the arm and it fixed my problem...thanks to hako.
    VY SS
    May 2011
    Auckland
    The gears on my vs nob were stripped. So I had to move the rod myself to go between hot and cold. Burnt myself a few times before I got used to it.
  1. VT - HSV (series 1) - Suspension 'fun'.... knocking/metal on metal noise
    By adept in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-11-2011, 06:21 PM
  2. VT Metal on Metal scrap noise
    By VRNathan in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-02-2010, 06:15 AM
  3. power steering rack busted metal pipe
    By farkamhall in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-12-2007, 12:34 PM
  4. VN Metal on Metal noise / Vibration
    By kerrin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-12-2007, 03:48 PM
  5. salesale - dump pipe, front pipe, high flow cat, catch can + more
    By venomous in forum Parts And Other Items For Sale
    Last Post: 19-08-2006, 06:20 PM
