Results 1 to 7 of 7
Thread: Help with bcm for vr Calais
    VY VC VK
    Mar 2009
    Default Help with bcm for vr Calais
    I brought another bcm and key head but unsure if it's same the one I pull out of my car is a 795 and the new one is 379 both have hi, I don't want to open the new one as if its not the same I can't get a refund
    VRCALAISS is offline Banned
    94 VR CALAIS 3.8L V6
    Jan 2011
    Morayfield,QLD
    VY VC VK
    Mar 2009
    I guess you didn't read the part where I said if I open it I can't get a refund let alone change it over for the right one
    Jan 2011
    Morayfield,QLD
    Quote Originally Posted by RedBull77 View Post
    get a statesman one with the right number preferably a vs one that's what i did.
    vr commodore
    Jul 2011
    south australia
    normally if the nbumbers arent the same then the bcm's r different, u really need to try and track down a bcm wit hte same number as ur original one, the key heads can be programmed but can only be programmed once so u need a set of new heads, its a head #### but only an auto elec or someone wit the right computer can set it up
    VY VC VK
    Mar 2009
    Was hoping I could just change the bcm that came with another key but now that seems impossible I was just hoping that someone could tell me if the 795 and the 379 were interchangeable as the 379 was out of another calais as I didn't want to open it up and find out it's not and that I was also told if it is the wrong one they can catch alight
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    If both are same level and have the same connections then one would assume it should work...
  1. [VIC] WTB: VZ SL Rears, VZ Calais wheels, VZ Calais tail lights
    By MorganVZ in forum Swap / Wanted to Buy / Trade
    Last Post: 22-10-2011, 09:13 PM
  2. [VIC] SWAP - SSL IRS springs for VT Calais door trims/Calais suede dash kit
    By sxc_sound in forum Swap / Wanted to Buy / Trade
    Last Post: 13-02-2011, 11:05 PM
  3. Replies: 5
    Last Post: 07-02-2011, 11:01 PM
  4. [SA] [WTB] VX Calais Chrome Strip and possibly VX calais aftermarket/genuine monaro lights
    By Robertoe in forum Swap / Wanted to Buy / Trade
    Last Post: 31-10-2010, 04:29 PM
  5. Replies: 0
    Last Post: 26-12-2007, 11:34 AM
