Results 1 to 5 of 5
Thread: Buick gearbox
    Vs evecutive s1
    Nov 2011
    Bayside
    Default Buick gearbox
    Does anyone know if the Buick gearbox bolts up to the Eco tec. ?
    Do I need a new bell housing or something like that I know there is a difference in wires but not ure how to bypass this problem
    Any help would be awesome
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Better of just buying a VS box alot easier and cheaper, is it a VN, VP or a VR box? The VN and VP boxes are cable operated.
    Vs evecutive s1
    Nov 2011
    Bayside
    hako is online now Donating Member
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    As you have a VS you MUST use a box that has the correct number of pins on the connector otherwise it just will not work properly (it can be overcome apparently but no one seems to know how!). So if your old box has 5HDD or 6HDD or 7HDD you should get one with the exact same identification. VR box will not fit as the plug has one less pin on it. As it takes a lot of time to change a box you want to get it right first time! - as an example, my bro-in-low and I took 3 days to change the box in my VS just 2 weeks ago....it ain't fun when you're both pushing 70!. A young bloke might do it in 2 days, or less with a hoist. Good Luck.
    vs Executive v6
    Dec 2011
    fairfield
    if your car a vr you can use a vs gearboxs but you cant use the vs in the vr.... but u can change the wiring harness in the transmission
LinkBacks (?)
  1. 15-12-2011, 07:14 PM
  1. [Buick] American buick pistons in VR buick motor
    By aleavy in forum V6 Development And Modification
    Last Post: 03-01-2011, 09:13 AM
  2. VS A4 Gearbox Leaking round the dipstick where is joins gearbox.
    By scogie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-11-2010, 11:23 PM
  3. buick v6
    By customvt in forum V6 Development And Modification
    Last Post: 09-12-2009, 05:45 AM
  4. buick v6.
    By VRV6BT1 in forum V6 Development And Modification
    Last Post: 16-04-2008, 02:11 PM
  5. vs manual gearbox / rebuilt strengthed auto gearbox
    By petezor in forum Swap / Wanted to Buy / Trade
    Last Post: 14-12-2006, 07:51 PM
