Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By Scrubmonk
Thread: vs v8 problems!!!! helpp
    vs ss ute 5ltr
    Jan 2010
    sunnycoast
    Default vs v8 problems!!!! helpp
    just driving along the main road today, all of a sudden she just stoped running?? pulled over and she will try to kick over but wont start.:/ all dash lights come on, any ideas whats goin on before i ring a machanic would be greatly appriciated! cheers
    VS GTS & VT XU6
    May 2011
    honestly there are a heap of things that could be wrong but with these the 2 main common things are coils and ignition moduel pull off one of the leads and check if its got spark if not try find a mate that has the same engine in his car and lend his moduel and see if that works if not try the coil if there is spark maybe the fuel pump good luck with it
    vs ss ute 5ltr
    Jan 2010
    sunnycoast
    VS Executive S2 V8
    Mar 2011
    Mildura, Vic
    1 Grab the fuel hoses at the back of the injector rail, as you turn on the ignition (without actually starting it) you should be able to feel the fuel in the lines and hear the fuel pump priming. If not, it is probably fuel pump related (either fuel pump, relay or fuse). Check the relay and fuses, try thumping the in-tank fuel pump to see if you can jolt it into moving again.
    2 Check for injector pulse - can you hear the injectors "ticking" as you turn it over? If no, then could be (in order of likelihood) - ignition module on inside left guard, - sensor in distributor, - ignition coil, - ECU.
    3 If you just have no spark, check your main fusible links and relays, could also be a dud rotor, distributor cap or ignition coil.
    4 Call your local Roadside Assist! Unless anyone else can add this.
    Good luck!
    vs ss ute 5ltr
    Jan 2010
    sunnycoast
    cheers for your help lads, yep its the ignition module, got a diagnostic done and thats the prob. new one on the way! champs!
LinkBacks (?)
  1. helpp .....
    By omad in forum General
    Last Post: 09-09-2009, 02:47 PM
  2. Problem with my vz helpp!!
    By BeKzZz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 30-06-2009, 10:23 PM
  3. kW and HP HELPP
    By s1nge in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-11-2007, 11:30 AM
  4. Something wrong with car i think...Helpp
    By Dragz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2006, 06:36 PM
