Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By fully_carver
Thread: Lowering vs ute
    Holden Vp Commodore series 2
    Feb 2009
    Default Lowering vs ute
    Simple question. Im trying to lower my vs ute. I have a rough idea how to do it but need a little help, im guessing you have to lower the rear control arm. Only problem is the bolt gets stuck between it and the hub. Any special way to bypass that? Or are the bolts the wrong way around?
    Wombles's Avatar
    Wombles is online now Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    You actually need spring comprressors. They should get it out.
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    Feb 2009
    I have compressors but do you need to drop the rear control arm to give you more room?
    VZ SV6
    Oct 2008
    Victoria, Melbourne,Croydon
    are you talkin about the rear? If you are just undo the shocks from the top then just stand on the hub and the spring will pretty much fall out with a little encouragement.
    vr
    Jun 2009
    i did this the other day i put a trolly jack under the arm and then undid the bolt at the front end of the arm then lowerd the jack no spring compressers pulled the old spring out put the bolt back in then the supper low king spring in after. this was on a non irs not sure what yours is. hope is is of some help sorry i dint take any picks
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Quote Originally Posted by fully_carver View Post
    i did this the other day i put a trolly jack under the arm and then undid the bolt at the front end of the arm then lowered the jack no spring compressors pulled the old spring out put the bolt back in then the supper low king spring in after. this was on a non irs not sure what yours is. hope is is of some help sorry i dint take any picks
    No IRS on pre - VU utes.
    VS UTE, HT MONARO REBUILD
    Dec 2010
    no need to undo any bolts if it's got stock shocks on it just raise up he rear prop the car body up, whip off the wheels drop the diff down and the springs should just sit loose, and then you just pry them out with a bit of force, when lowering its andvised you put on shortened shocks to keep the springs captive and also an adjustable panhard is always good to keep the rear end in line.
  1. lowering front without lowering rear.
    By pillzor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2011, 09:46 PM
  2. lowering my sv6
    By ned in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-04-2009, 04:47 PM
  3. VX lowering
    By Siliconslick in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-02-2009, 12:24 PM
  4. Lowering Vp
    By King_berald in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-12-2008, 09:41 AM
