Results 1 to 15 of 15
Thread: 284 or 276 cam for 5 litre?
    vs 5.0l ute
    Mar 2011
    pertg
    Exclamation 284 or 276 cam for 5 litre?
    Hey guys, just after info on a cam for my 5 litre.
    Having a bit of trouble deciding on which cam I should put on my ute.
    Pretty much my mates have swung me in the direction of the crane 276 and 284 cams. Problem is I dont know which one to get. Now to a Lil info on the small growing list of mods
    3 inch cat back
    K&n filter
    Otr intake
    Running 98 fuel
    Oh and its a manual
    Planning on putting 3.9s in the diff so dunno If that will help
    Any help will be appricieted thanks
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    BASIC RPM 1800-4500
    Compucam H276
    214/214 .464 .464
    276/276
    110 LSA
    BASIC RPM 2200-5500
    Compucam H284
    222/222 .480 .480
    284/284
    112 LSA
    They seem ok but I think this camtech grind would work really well 222/222 112 LSA .511" .511
    it has the same duration as the 284 but more lift
    vs 5.0l ute
    Mar 2011
    pertg
    Munz's Avatar
    Jan 2011
    Brisbane NTH
    vs 5.0l ute
    Mar 2011
    pertg
    Yeah Righteo. Say if I didnt get diff gears just yet which cam would give better performance over the stock one
    Munz's Avatar
    Jan 2011
    Brisbane NTH
    Doesn't really matter if you get diff gears or not. It just brings the cams powerband on quicker
    What Gearbox A4 or M5?
    vs 5.0l ute
    Mar 2011
    pertg
    Munz's Avatar
    Jan 2011
    Brisbane NTH
    So you'll need a clutch upgrade..... eventually
    what series? cause if its series III its gonna change your cam options as its the later 'roller block'
    vs 5.0l ute
    Mar 2011
    pertg
    VS Executive S2 V8
    Mar 2011
    Mildura, Vic
    Depends so much on what else you plan to do with the motor, and what you are using it for. Highway cruising, running kids to school or drag racing and speedway? There are heaps of different grinds to go for. Do it once and do it right. A lot of bigger cams need different diff ratios, higher compression ratios, stronger valve springs etc to be effective.
    Crane cams now do roller lifters to fit into pre VT non-roller blocks, allowing you to consider the option of going with a roller cam (allows the cam to be more agressive in its shape, giving bigger valve lift with shorter duration).
    Have a good look at Greenfoams cam selection thread, it is a sticky under V8 Development forum on Just Commodores.
    Personally I have a Wade 963A961A10 in my 5L. Great fun for everyday driving and good fuel economy, but not suited to higher revs. Works well with the std intake manifold, std valve springs, std compression and torque converter.
    vs 5.0l ute
    Mar 2011
    pertg
    Cheers for that one mate. I use it running to work and everyday driving. Do want it to be quicker but. How does ur cam go performance wise is ur 5l
    VS Executive S2 V8
    Mar 2011
    Mildura, Vic
    Quote Originally Posted by satinblackv8 View Post
    Performance wise it is probably about the equivilent of a HSV 185i or maybe a little better. Goes from about 2000 RPM to 4500RPM very quickly and easily, but then the show is over. Still has plenty of low down torque, which is something that disappears as cams get bigger. I should add that I also have a full 2.5" twin exhaust, 70mm throttle body, K&N, CAI, Roller rockers, and a tune from Greenfoam.
    If I was to do it again, I would probably up the compression ratio by shaving the heads, put a dual plane intake and quad throttle body, bigger stall convertor, stronger valve springs and put in a more aggressive roller cam setup. But I'm just talking s*$%t now.
    vs 5.0l ute
    Mar 2011
    pertg
    Munz's Avatar
    Jan 2011
    Brisbane NTH
    Quote Originally Posted by Scrubmonk View Post
    surely its gotta go better than that?? 185 is just intake/xhaust and ecu mods from factory
    Series 2 man. What bout the lifters. Coz crane cams do 3 options
    You won't need lifters but replace if your taking heads off!
  15. #15
    vs 5.0l ute
    Mar 2011
    pertg
    Cheers for the help boys appreciate it !!!
  1. VH SL/X 4.2 litre Air Con??
    By AndrewC in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-06-2011, 10:09 AM
  2. VT 5.7 litre
    By 1998GTS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2010, 07:47 PM
  3. HSV VT 5 Litre vs Standard 5 Litre
    By Oken in forum General Discussion
    Last Post: 03-08-2009, 06:56 PM
  4. 6 litre or 5.7 litre conversion
    By kohan in forum LSx Development and Modification
    Last Post: 28-06-2009, 01:43 PM
Tags for this Thread
