Hi guys.
My Vr ss has a strange central locking problem.
When you try to lock the car with the key pad the passenger and to rear doors lock and then unlock straight away. The drivers lock doesnt move. Its only just started doing this.
What could be the problem?
mine does strange things sum times too however yours sounds like its the drivers lock actuator sticking or stuffed, try manually locking it and unlocking it see if it loosens it up
take the trim off and lubricate the lock and actuator if that don't work replace the actuator
