Results 1 to 8 of 8
Thread: Doe's this sound like warped rear brakes?
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Default Doe's this sound like warped rear brakes?
    hi, when breaking in my vs sometimes while coming to a stop (moderate braking) the car sort of jolts forward and back and i can feel the brake pedle going up and down, no shaking in steering wheel etc just this, kinda like braking then pedal pushes up then braking (but a lot quicker), is actually dangerous sometimes. could it be the diff??
    any help?
    thanks
    vr
    Jun 2009
    it sounds exactly like warped brakes way to test remove wheal and put a steel ruller on the disk best done hot. i saw in the repco caterlog disks and pads for 100 bucks a pair
    hako is online now Donating Member
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    fully_carver is on the money - warped or distorted brakes....could be front or rear. Disks are cheap and an easy change..
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by hako View Post
    Well sometimes they are.. on a donar VS I had here I could not get the front ones off,,,
    Jan 2008
    NSW
    Quote Originally Posted by James39 View Post
    Thats when you reach for the hammer!!!
    Note: if your not going to use the rotor again use a normal hammer (otherwise a rubber mallet). You kind of have to shock it to break its hold/seal. Sort of like using a spanner and hammer to shock a seized nut. (It think thats the term, 'shock', so dont crucify me if its not, im an accountant not a mechanic lol)
    TI3VOM's Avatar
    TI3VOM is offline VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Yep sounds like the REAR brake rotors are possibly warped, if they were the front you would have your steering wheel shake, if there the back you will feel it in the pedal.
    VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
    Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    thanks guys will sus it out, i got a set of disks here mite try and change em one by one and see, as i got slotted disks all round (RDA front and DBA rear although they were bothe DBA front and rear i got em seconhand and the fronts warped straight away so it could be the backs, anyway got brake fad last night for the first time (scard me lol) buut i was useing them pretty hard etc)
    will get around to it and let yous no how it goes
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Before you try and get the rotors off, spray around the bottom of the wheel studs where they come out of the rotor with a penetrating agent, such as Penetrene, WD40, RP7 etc. Let soak in for 5-10 mins before you try and remove the rotors.
    IMPORTANT - make sure you let the handbrake off before you try and remove the rear rotors.
  1. rear brakes sound like shit
    By te_rarawa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-10-2009, 12:14 AM
  2. Brakes warped.... again!
    By adamc11 in forum General
    Last Post: 08-12-2008, 01:17 PM
  3. Using Harrop Adapter to fit VT-VY rear brakes to VL-VS solid rear axle
    By Surfwagon in forum Holden Commodore How-To's
    Last Post: 26-11-2007, 04:46 PM
  4. vs warped air bag fix?
    By chopper900 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-02-2007, 07:00 AM
