Results 1 to 11 of 11
Thread: vs 286 cam
    vs 2
    Dec 2011
    mt gambier
    Default vs 286 cam
    just put a tune and 286 cam 3200 hi stall in my v8 vs. it idles good in p or n 1100 0r 1200 rpm but in gear it idles fast 1500 and up and allways trys to go any help would be great . thanks rich
    VS GTS & VT XU6
    May 2011
    that will be the tune you will need to get it touched up to reduce the idle speeds you may be able to reduce it a little adjusting the idle stop on the throttle body it sounds to me a generic tune and its set to idle high to prevent stalling
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    What compression and manifold are you running?
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    vs 2
    Dec 2011
    mt gambier
    Default 286
    all standard . car runs the same with the standard chip just wont idie.we done the same mods to my vs as a mates vr and his runs fine.
    Reaper's Avatar
    Aug 2004
    I'm not surprised. 286 is waaaaaay too much cam for a stocker 5 litre. 268 is about as big as I would go for any stock comp 5 litre. Maybe 276 with 9.5:1 and stock manifold. The only thing a 286 cam will give you on a otherwise standard motor is a loapy idle, crap bottom end and just when it starts to get going lack of compression + bananas will strangle the top end. Car will most definitely be slower down the 1/4 by a long way. Whoever recommended that cam to you should hang their head in shame.
    Rule of thumb with cams, tb's and pipes - less is more in 95% of cases.
    Reaper
    Reapers Black VP SS
    vs 2
    Dec 2011
    mt gambier
    Default 286
    thanks for your input reaper. but it does not help fix the clubby . its just a cruiser i have had a long time the cam is just for a note as thats all i wanted . if i was after power i would have done up the wifes vz ss.
    Reaper's Avatar
    Aug 2004
    Quote Originally Posted by rich View Post
    That's the point. You won't get a good idle. Put in a (much) smaller cam and you will have a good note, a car that idles and something that is *much* better to drive.
    Reaper
    Reapers Black VP SS
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    as reaper said 286 came way too big for a stock donk. my brother threw a 286 and hi stall in his vs...... ive got a stock 5.0l in my vh and now i dust him, before we were pretty even. oh and it ran like a pig so he ended up building the rest of the motor to suit the cam....a completely back to front approach of chasing a few more ponies. but once tuned for low idle did sound sweet
    vs 2
    Dec 2011
    mt gambier
    Cool 286 cam
    got the vs back today . base timing was out and and throttle postion sensor was playing up. car runs fine now.has great power from 2800 and sounds good. just needs diff gears now . any ideas what ratio ?
    VR Berlina
    Jun 2010
    VIC
    Reaper's Avatar
    Aug 2004
    Start at 7:1 and see how that takes you.
    Reaper
    Reapers Black VP SS
