Results 1 to 2 of 2
Thread: speedo not working after manual conversion on vr
    vn calais 5ltr
    Aug 2010
    Default speedo not working after manual conversion on vr
    i have a vr and have done a manual conversion i took everything from one car and put it into another does not have right loom for manual but was working fine in the other car.
    it has worked a couple of times for a bit then stops what do i need to do
    hako is online now Donating Member
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If it works sometimes and not others it must be a bad connection so all you can do is recheck every connection from the speed sensor on the gearbox to the ECU and then the dash.....
  1. VR V8 manual. Speedo not working
    By ceptavl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2011, 11:58 AM
  2. vr manual conversion speedo
    By giffo2010 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-06-2011, 02:46 PM
  3. vn v8 conversion into v6 vs, speedo not working
    By Patto68 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-11-2010, 09:06 PM
  4. VR Manual Conversion - How to Get you speedo working again using the auto harness
    By mal62 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-05-2010, 03:35 PM
  5. Speedo stopped working on Manual 3.8 VN
    By bjj in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-04-2009, 06:52 PM
