Results 1 to 10 of 10
Thread: vr handbrake doesnt work
    GENESIS BLUE VR COMMODORE
    May 2011
    Gippsland, Victoria, Australia
    Default vr handbrake doesnt work
    hey guys
    ive read heaps of threads and read my book on this and seriously dont understand anything
    handbrake doesnt work ive gone under the car and done the bolt up on the Y peice and still nothing
    do i have to rip out the console or is it the shoes?
    thanks
    muttley383's Avatar
    muttley383 is offline Donating Member
    VR 383
    Sep 2007
    you have to check the adjustment of the shoes.
    You need to set the shoe adjustment to approximatley 0.5mm smaller than the rotor internal diameter, then adjust the cable yoke to take up the remaining slack.
    From memory I think the handbrake is supposed to hold when activated 6 clicks from the disengaged position.
    muttley383
    hako is online now Donating Member
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If the book you have is a Gregorys there is a good write-up on adjusting the handbrake at the rear drum - this has to be done first as Muttley3838 says and there really are no short cuts you can take if you want it to work properly. If you don't have a Gregorys, PM me your email and I'll scan the page.
    May 2011
    i couldnt find gregorys, i got another one like gregorys whats got a diagram of the Y peice and a little right up peice what i couldnt understand if it ment rip the console out or adjust it from under the car lol
    May 2011
    muttley383's Avatar
    VR 383
    Sep 2007
    Adjust the shoes first then get under the car and adjust the cable yoke.
    muttley383
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Release the cable adjuster under the car to the fully loose position before adjusting the shoes.
    Then re adjust cable.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Ellery's ain't Gregorys...neither is Haynes - forget the Y piece as that is the final adjustment - unless you adjust the shoes at the brake drum you will never get it right. As I offered before, PM me your email address and I'll scan and send the relevant page from the Gregory manual on adjusting the handbrake.
    vr statesman 5.0 + vs exec s2 auto
    Mar 2006
    central coast, nsw
    release the handbrake lever then slacken off the equaliser adjuster [ y piece ] then you can tighten up the shoe adjusters so that the disc hub is just free without binding then you can adjust the equaliser to remove slack in cable , and try handbrake lever should lock the wheels if you yank it up half dozen clicks.make sure then the rear brakes dont bind on the disc hub after releaseing handbrake lever......
    May 2011
    just went to take the shoes off and there stuffed off to the shop tomorrow AGAIN i guess lol
  1. VR 1994 Indicator doesnt work (Hazard lights work)
    By rester in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2010, 01:40 PM
  2. Thermo fan doesnt work
    By vscommo95 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2010, 03:23 PM
  3. stereo doesnt work why?
    By SAV_117 in forum Car Audio
    Last Post: 19-01-2010, 08:58 PM
  4. engine just doesnt want to work.......
    By 9898989 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-07-2006, 05:51 PM
  5. brand new key doesnt work. help plz!!!
    By ultimate_vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-05-2006, 07:29 PM
