Results 1 to 4 of 4
Thread: vs senator power up grade
    vs senator
    Dec 2011
    Liverpool
    Default vs senator power up grade
    Hi guys I was wondering if someone could help me out, I have just bought a vs senator with the running gear out of a vt senator. It has the 215i motor in it.
    I was wondering if and what I could do for some more power. It all ready has exhaust extractors a lumpy cam (not sure of the size) that's about the most of it. and as far as I know these engines cam out with roller rockers and mild head work work already done
    Was wondering if there are any other mods I can do apart from supercharging, that would give me some extra power, ie computer upgrade , diff or what ever.
    Be good to hear where I should start from here
    Thanks Chris
    VS GTS & VT XU6
    May 2011
    mate if its a VT motor its a 220kw not 215kw and no these motors did not come with roller rockers or head work so if you looking for power the biggest thing holding you back is the manifold there is about 10-20% more power in stock form using a better manifold if it has a cam maybe even more up to 30% more.
    So again providing it does have a cam id go manifold and heads next then get it tuned to suit knowing the cam specs will help you alot.
    and if its auto get some 3.45-3.7 diff gears if its a 6 speed get some 3.9-4.11 gears
    VR Senator/VS Statesman/VS Calais
    Dec 2011
    Just stroke it, if it has the vt roller engine in it you should be right for clearance...
    VS GTS & VT XU6
    May 2011
    if its a 215kw or 220kw motor it is already stroked
  1. oil grade
    By rocket0000 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-03-2011, 02:08 PM
  2. Looking for a memcal up grade
    By holden_calais_VT_1999 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-02-2011, 03:17 PM
  3. what grade of oil to use
    Last Post: 14-10-2010, 07:36 PM
  4. what grade oil should i use?
    By RUstyplastic in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-01-2010, 10:08 PM
  5. Oil Grade
    By kenwstr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-11-2006, 05:39 PM
