Results 1 to 6 of 6
Thread: Aircon fuse keeps blowing
    VS ute
    Jan 2010
    townsville
    Default Aircon fuse keeps blowing
    G'day all,
    I replaced my compressor the other day and regassed the system.
    Zircon was working nice and cool for two days until it started constantly blowing fuses (a/c fuse)
    Anyone know if this is common or how to fix it?
    VC SL/E A3300 ,Looking for a VL
    Mar 2011
    armadale Perth, Australia
    re-check everything you stuffed with?
    Black_Stig
    If Cars could scream Rape, I'm sure yours just did because I just eye fuc&ed the shit out of the above images.
    MY 1980 VC SL/E Exhaust Note
    hako is online now Donating Member
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Try isolating the fault.....1..disconnect compressor magnetic clutch....check fuse....if OK.....2...press ac button to disconnect ....if OK.....3...turn fan on with 1 and 2 connected.
    This way you will have a better idea where the short is. Good Luck.
    newfarmcowboy's Avatar
    newfarmcowboy is offline 50th Ann. Ed. VS II Ute
    1998 VS 50th Anniversary Edition Ute
    Sep 2007
    Hey mate i have the same problem...blows fuses 1 after the other...and my air con is'nt working either about to replace the compressor....let us know how you solved the prob?
    VS ute
    Jan 2010
    townsville
    fuse is good now but the switch light isnt going on, does this mean no power is getting to the switch?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by patskies View Post
    But is the aircon working OK now?......if it is then it's probably just the globe gone.
  1. My fuse for the dash lights is blowing (number 1 - 15amp fuse)
    By aussie7 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-02-2011, 06:10 PM
  2. fuse blowing
    By tex66 in forum Electrical Wiring / Questions
    Last Post: 12-01-2010, 04:26 PM
  3. Blowing fuse VS V6
    By TrustNo1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-07-2008, 04:48 PM
  4. My car keeps blowing fuse
    By bellasmummy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-01-2008, 06:24 PM
  5. A/C blowing fuse VP
    By twasm6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-12-2006, 07:29 PM
