Results 1 to 5 of 5
Thread: To kick it off.....
    '93 VS Ute
    Dec 2011
    Default To kick it off.....
    Hi Guys,
    I have had my VS ute for about a year now. She was a bit of dud when i got her however when it comes to a choice between driving my new car and the VS ute it always wins hands down. So now it has come time to fix it all up and getting her looking sexy.
    But unfortunately i have a problem to kick it off.
    The ute runs hot. What i mean by this is when i sit at lights or when driving around the city the ute will run hot. It never boils but will sit up high on the temp gauge and it smells hot as well. I have been to two mechanics who have said that it looks like a timing problem with the fan on the radiator. Does that sound right? I have replaced the thermostat and done radiator flushes and hasnt made any impact. While driving on the freeway or out in the country it is fine and have no issues.
    As i said the car has never boiled, even on a 40 degree day in the middle of summer this problem occurs but still does not boil.
    So whats next, do i start replacing radiators and fans?
    Cheers guys, i look forward to reading and posting!
    Az
    VS Acclaim
    Feb 2010
    hey mate,
    my vs acclaim does this as well. when sitting in traffic around town it will get to halfway and the fan will turn on and then the temp will go back down to about one third.
    i have had the thermostat replaced twice, but from what I can gather, it seems to be normal for this model of car to run hotter.
    cheers,
    aaron
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    How hot is hot?
    As above, halfway or thereabouts on the temp gauge and fans kicking in is normal.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    VS Berlina/ KJ Verada
    Sep 2006
    You might need a new temp sensor.
    95 VS Berlina
    http://forums.justcommodores.com.au/...ml#post1891856
    I need some statesman/ calais woodgrain for drivers side panel!!
    hako is online now Donating Member
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It is normal!......many people before you have spent many $$$$ trying to get their VS to run cooler but failed. Believe it or not but they are designed to run at these (apparent) high temperatures. If the engine overheats it will sound an alarm but that will only happen if something like your waterpump fails. They do not overheat unless there is a fault with the engine or cooling system.
  1. kick panels
    By myvq5ltr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-03-2007, 01:20 AM
  2. does your vr/vs kick into 4th at 40kmh????
    By commod8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-03-2007, 02:20 PM
  3. kick ass kickers
    By BeNoS in forum Car Audio
    Last Post: 25-01-2007, 08:52 AM
  4. Kick Down
    By daggett in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-12-2004, 02:01 AM
Tags for this Thread
