Results 1 to 3 of 3
Thread: VR Statesman V8 starting prob with Diagnostic faults 15 and 16, what do they mean????
    VR Statesman V8
    Dec 2011
    Collinsville
    Default VR Statesman V8 starting prob with Diagnostic faults 15 and 16, what do they mean????
    Hi, I have a '94 VR Statesman, V8 5L, automatic.
    Have been having trouble starting it, winds and winds until you think the battery is going to die then she'll start for a moment then die. Can end up doing this up to 6 times, OR sometimes she'll start on the first try. Doesn't matter whether it is hot or cold.
    Rang a mechanic, told us to a diagnostic on it, came up with the following:
    12 System Pass OK
    15 ECT sensor - voltage too high (Auto transmission only)
    16 ECT sensor - voltage unsteady
    Mechanic and his boss thought the prob was a Temperature Sensor, we that was replaced, still coming up with the same Diagnostic faults.
    Now she won't idle properly, have to hold foot down when starting to keep revs up, to move her around the yard.
    Does anyone know what these faults mean, I need this car to run, it's my family car!!! HELP!!!
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Just make sure the coolant temperature sensor was replaced (measures the coolant temperature for the PCM/ECU) and not the temperature sender which measures coolant temperature for the temperature gauge on the dash. After replacing the sensor, was the battery disconnected or the engine fuse removed for a couple of minutes to reset the PCM/ECU and any recorded diagnostic codes? If not you will still be seeing the old codes. If you are still getting the codes after the PCM/ECU was reset you need to inspect the ETC sensor connectors and wiring harness, and the PCM/ECU terminals D16 (ECT sensor temp signal) and D3 (sensor earth) for corrosion.
    VR Statesman V8
    Dec 2011
    Collinsville
    Thanks for the info,we didn't do the battery or fuse thing, so we'll check it tomorrow, and see how we go.
  1. vy ute starting prob
    By YMY-88U in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-12-2009, 10:39 PM
  2. *URGENT* VR Statesman has faults
    By XLR87N in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2009, 02:19 PM
  3. starting prob v6 vs
    By bazchch in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-10-2007, 07:49 AM
  4. VS seriesII starting prob
    By hold-on in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-02-2006, 07:34 PM
  5. Prob with damn warning tones (vq statesman)
    By BassDJ in forum Electrical Wiring / Questions
    Last Post: 01-07-2005, 10:09 AM
