Results 1 to 6 of 6
Thread: Lumpy sound VS Stato
    VS 3.8 Statesman
    Dec 2011
    Default Lumpy sound VS Stato
    Howdy Peoples,
    I have an interesting problem. I have a VS Statesman and the most recent of problems to rear its ugly head is an awful lumpy sound from the front left wheel.
    I first thought a flat spot on a tire so changed all four, I thought maybe a wheel bearing so I changed that. I replaced tie-rods and did a thorough check for witness marks of which there are none. The problem seems to gain volume and ferocity whilst turning right however, turning left the sound is almost gone.
    Any help would be much appreciated.
    hako is online now Donating Member
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Wouldn't be the engine mount on passenger side sagged so badly it is metal to metal?. I had very similar problem some years ago - replaced wheel bearing ($400), both front discs and pads and then discovered it was the cheap chinese tyres on the front which apparently did not have a 'bead breaker' or something when manufactured - this meant the tread squirmed about only on RH turns for some reason or other. Change tyres and then OK...but you've done that already.
    Welcome to the forum as well!
    1999 Holden VS Statesman
    Nov 2010
    As said above, it might be your discs or maybe a warped or distorted piece behind the wheel.. Have you hit any gutters are pot holes hard? you think if something was noticeably wrong the tyre people would notice it...
    Last edited by fallen1; 15-12-2011 at 02:30 PM. Reason: Edited because it had atrocious grammar.
    VS 3.8 Statesman
    Dec 2011
    Cheers for the responces guys,
    I havent hit any gutters no. But I will definately check out the Engine mounts and see whats up
    VS 3.8 Statesman
    Dec 2011
    They seem to be fine. I adjusted the toe with the tie rod the other day and the noise seems to have switched from turning right to turning left... Im gonna get a wheel alignment done to see if thats the problem.
    I will be in touch.
    Wombles's Avatar
    Wombles is online now Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Could a sway bar bush or something be gone?
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
  1. Lumpy Cam
    By Jecs in forum V6 Development And Modification
    Last Post: 10-10-2010, 12:30 AM
  2. VT 5L Lumpy Cam help
    By MattyC in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-07-2010, 09:42 PM
  3. Lumpy Cam
    By vpdrifta69 in forum General
    Last Post: 24-04-2010, 05:10 PM
  4. lumpy cam
    By tionaboy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-03-2010, 09:24 PM
  5. getting lumpy
    By blaze in forum V8 Development and Modification
    Last Post: 22-11-2009, 09:25 PM
Tags for this Thread
