Results 1 to 4 of 4
Thread: 94 VR trans
    94 VR Commodore
    Dec 2011
    mount gambier
    Default 94 VR trans
    hi im wondering what i need to do. my auto vr takes a while to kick into gear once upto 3000rpm it goes into 2nd gear an then for the following gears kicks in at 1.5 _ 2000rpm, does it just need a service or do i need to get it recond?? thanks in advance
    vr commodore
    Jul 2011
    south australia
    94 VR Commodore
    Dec 2011
    mount gambier
    hako is online now Donating Member
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Before you go spending big Dollars, check that what you describe is not normal as mine changes at about the same revs - Commodores change different to smaller 4 cyl cars. Good Luck.
  1. [VIC] Swap- my vn-vp v8 trans for a vs v8 trans
    By Gunns VC in forum Swap / Wanted to Buy / Trade
    Last Post: 28-01-2011, 08:01 PM
  2. wiil a 7hbd trans replace a 5hbd trans in a vs ss??
    By droppedpiez in forum Mace Engineering
    Last Post: 09-10-2010, 09:47 PM
  3. [NZ] l67 trans ecu and loom and subframe trade for 5l trans ecu,loom and subframe
    By Nzpure in forum Swap / Wanted to Buy / Trade
    Last Post: 21-04-2010, 09:51 AM
  4. Changing a Vr auto trans to a vn auto trans
    By phildo_mmmk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2010, 11:35 AM
  5. Auto Trans problem when hot - need a trans cooler ??
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:41 PM
