Results 1 to 4 of 4
Thread: vs 5ltr gearbox whine, help!
    vs ss ute 5ltr
    Jan 2010
    sunnycoast
    Default vs 5ltr gearbox whine, help!
    hi guys, my gearbox (getrag) has a pritty bad whine , the only time it dosent whine is when the cluch is pressed in. would this be my throwout bearing? cheers for your help.
    304runner's Avatar
    304runner is online now ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Yeah, sounds like you have a spent throw out bearing... Shit of a job to do, might as well put a new clutch in if you can afford it.
    hako is online now Donating Member
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It could be the gearbox input shaft bearing that is noisy especially if it is also present in neutral. Throwout bearing should make a noise when clutch is pressed in if it's bad - when out it is not moving. Maybe the oil needs changing or is low....heard there are some good treatments to stop a whine but if the bearing(s) are worn they will eventually fail. I note you say whining and not grinding so hopefully it ain't major.
    vs ss ute 5ltr
    Jan 2010
    sunnycoast
    yeah there is just a whine, no grinding, and yep its there as soon as i start car up, so in neutral it whines too, if i put the clutch in it stops whineing. sounds like a gilmore drive?
  1. Gearbox problems again VS 5ltr
    By VS304exec in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-06-2011, 07:49 PM
  2. VT T56 gearbox grind/whine
    By muggo05 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-03-2011, 12:06 PM
  3. Gearbox Whine
    By VK SL 3800 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-05-2010, 08:46 PM
  4. [SA] 5 spd gearbox for vn 5ltr
    By Phat VN in forum Swap / Wanted to Buy / Trade
    Last Post: 20-12-2009, 02:44 PM
  5. 5speed gearbox whine
    By marcuscarter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-12-2008, 12:31 PM
