Results 1 to 7 of 7
Thread: VR Commodore lost all power while driving
    VR Commodore
    Dec 2011
    wynnum
    Default VR Commodore lost all power while driving
    my parents have just bought me a VR Commodore as my 18th birthday present and its only the 3rd time i have driven it we were only driving for about 5 minutes and all of a sudden no power at all. tried to start it sounded like it wanted to start but wouldnt then my step dad fiddled with something in the fuse and electrical centre and now nothing at all when u try to start it. can anyone give me an idea of what it may be please?
    V6 VR Acclaim
    Jun 2010
    First thing to check would be your fuel pump mate. Get somebody to jump in and turn the key to "Reds" while you listen at the back of the car below where the filler cap is.. Basically just stick your head near your rear tyre.. Once the key hits reds, you should hear a high-pitched whirr that lasts for a brief moment (Depending on your definition of time).
    If that noise is not present, then I am guessing you have killed your fuel pump.. This is usually caused by either running the tank dry too often or dirty fuel.
    GothicKidd's Avatar
    GothicKidd is online now ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    Not sure what you mean when you say 'power' but I'd say check your battery leads, jiggle them around abit and tighten if needed. check out your fuses in your engine bay one by one seeing if maybe one has blown and report back? :P
    GothicKidd's Ride
    I push the pedal to the floor, smoke them up and go.
    hako is online now Donating Member
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Welcome to the forum - if you want to save $$$$ and learn how to do your own maintenance you are at the right place.
    You should also see if there are any error codes logged - all you need is a paper clip and the instructions: Checking error codes VR/VS (Revised)
    Good Luck.
    VX Calais LS1, VS Calais L36
    Mar 2010
    Engine still cranks but won't start?
    An engine needs three things to start; ignition (at the right time), fuel and compression.
    Check ignition by pulling a spark plug and checking for a spark when cranking, check for fuel by a wet-with-fuel plug after cranking.
    Unless something went bang, compression will be fine.
    VE Omega
    Oct 2011
    The initial fault sounds like your crank angle sensor is dying, sits in behind the harmonic balance. I believe this is a fairly common fault. Not sure what your step dad may have done though.
    vr executive 1993
    Aug 2010
    manly
    Would say its the sensor mine kept doin it in bad traffic its not to costly an easy as to do yourself.changed mine ova 2 months ago an not a prob since
  1. 2000 VX Commodore Berlina Losing Power While Driving
    By thrifty1984 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-07-2011, 10:35 PM
  2. [Ecotec] lost compression while driving
    By bigneilsen in forum V6 Development And Modification
    Last Post: 23-03-2010, 04:42 PM
  3. driving along when suddenly all power is lost
    By arc angel vn ss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2009, 08:40 PM
  4. Almost lost power when driving
    By [Linkin Park] in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-03-2009, 04:50 PM
  5. Vs Commodore Lost all Power. Idles Fine! Help
    By 10571z in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-10-2008, 03:37 PM
