Results 1 to 7 of 7
Thread: VS calais stock to super6
    VR Senator/VS Statesman/VS Calais
    Dec 2011
    Default VS calais stock to super6
    Guys,
    I have a v6 VS calais that i bought a stock supercharger running a 10psi pulley, I bought the whole conversion kits (idler pulleys and all) just to find that one of the heads is cracked (between the valves) now i have been told that the super6 heads are very different to stock, the Injector bosses are bigger and they are more flowed etc, so i was curious as to weather i could drill out the injector bosses and run stock heads or if i just drill one out and use the good super6 head and a stock one if it will create to many problems. I dont have much knowledge on the super6 set ups. Its a budget build as the full charger kit only cost me $600 so im looking at the cheap way out haha.
    Your help will be much appreciated.
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    This is not that uncommon for L67 heads. The differences between L67 and stock ecotec heads is only in the injector being seated direct in the head rather than in the manifold like the ecotec. There is no differences in port sizes/shaping etc and run the same valves and springs etc. L67 heads actually come from the same mould as the ecotec and just have the boss for the injectors drilled out from factory. So, yes you can modify stock ecotec heads to use in an L67 application by drilling the correct size and angled holes in the boss.
    If you want to consider another set of factory L67 heads I have a pair for sale at the moment and asking $250.
    Cheers,
    Chris
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    Dec 2011
    Thanks mate, Yeah im very interested, are they in good nic? the heads are the only thing stopping me from bolting it all up. also with the compression factor the engine im putting it on has about 220000kms on it and i noticed from research that the L67 comes out with a lower compression ratio, i havn't had a chance to compression test the engine yet but im assuming with the compression loss over the time that the engine should hold 10psi?
    PM me your mobile number and ill talk to you more about the heads over text?
    Aug 2008
    NSW South Coast
    L67 run 8.5:1 compression ratio as compared to the ecotec at 9.8:1
    The higher compression is not in your favour in a boosted application, but with no more than 10psi max it will handle it fine. Internally the only other L67 difference is they run heavier forged rods and a larger diameter gudgeon pin.
    PM sent
    PM Me For Details
    Dec 2011
    Yeah, well its only going to be a daily, just want a bit more go then the stock 6 so it wont be getting a flogging haha
    VS GTS & VT XU6
    May 2011
    i wouldnt be running the 10 psi pulley you will more than likely have detonation issues with the higher comp of the ecotec bottom end
    Dec 2011
    The kits came with it and it has a bolt on bolt off pully, if i can get away with running 10pound if i just cruise then i will but fingers crossed nothing bad happens haha, have any of you guys heard about copper compound headgaskets and if they are any good?
  1. 1997 calais s2 super6 airbag light
    By Nzpure in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-12-2009, 09:12 PM
  2. help with my VY super6 calais
    By darryl_kay83 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-09-2007, 04:49 PM
  3. VX calais super6
    By army in forum Vehicles For Sale
    Last Post: 26-04-2007, 10:54 PM
  4. super6 vt calais possible purchase
    By evil_monkey in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-11-2006, 07:34 PM
  5. VK Calais stock auto to stock 6 cylinder manual.
    By TheKnightTemplar in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-07-2005, 08:01 PM
