Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By Andrew426
Thread: sounds like a 4x4
    vr v8 ute
    Dec 2011
    qld
    Default sounds like a 4x4
    hi again..after driving the old girl 3oookms she has developed a wiiring sound(like driving on 4x4 tyres)not being able to get under her.could it be the tail shaft or maybee a wheel bearing.??...or ???
    vr v8 ute
    Dec 2011
    qld
    vr v8 ute
    Dec 2011
    qld
    unlike the older holdens the drive shaft is in two pieces...could that be the prob.???
    de_overfiend's Avatar
    de_overfiend is offline Beef is Good
    VS Calias
    Aug 2008
    Tweed Heads
    could be the centre bearing in the tailshaft..... wheel bearing you can usually hear in one corner of the car louder
    vr v8 ute
    Dec 2011
    qld
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Have you checked you dont just have something caught in your wheelarch and rubbing against a tire? Does it do it when coasting in neurtal? Does it do it when your stationary, in any gear?
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    1997 VS Berlina
    Apr 2011
    South Sydney
    Jan 2008
    Jacking up the car and giving the wheels all a spin and checking for play in your wheel bearings is probably a wise move before you go driving another 1000km on it. Also check for stuck or binding brake calipers, damage to or delamination of the tires, fouling of the driveshaft or wheels on the exhaust or chassis. If you are unable to do this yourself take it to a mechanic nearby who can.
    Asking on here with such a vauge description of the fault, then continuing to drive 1000+km on it thinking its ok because somebody with dubious mechanical experience who hasnt even seen the vehicle said it was ok is nothing but irresponsible.
    vr v8 ute
    Dec 2011
    qld
    andrew.thanks ..having only worked on the older holdens(hr-hz)was hoping someone could save me some time in trying to pinpoint the noise.its not long gone through the paces of a blue slip last month.only traveled bout 60 kms since,but having looked into the workings of the tail shaft its likely to be in the centre bearing case...and am just using this site as a guide..
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    What tyres have you got on it? Could be a tyre noise. Also might even be the diff. Does it happen between at certain speeds (80-100km/h etc) or is it there all the time?
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    VS SS 5L
    Oct 2008
    You really have to go through a process of elimination, like most things that go wrong with cars.
  1. sounds of water
    By robin sonntag in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-06-2010, 04:10 PM
  2. !!!Every VR sounds the same??
    By slappedvr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2009, 10:30 PM
  3. Sounds like a wrx!
    By blacknight in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-03-2009, 01:38 PM
  4. Which supercharger SOUNDS the best??
    By savage1987 in forum V6 Development And Modification
    Last Post: 02-04-2006, 11:27 PM
  5. Sounds Better... Looks Better...
    By jazza21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2004, 12:41 PM
