Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Thread: Vr Start up problem
    vs calais s2
    Oct 2011
    Baulkham Hills
    Default Vr Start up problem
    I have recently picked up a vr Calais. it currently has a bit of a problem when i try to start it up. if i prime the fuel pump once and try to start it will try to kick over for about 5-6 seconds before it starts, but if i prime the fuel pump 2-3 times and pump the fuel with the accelerator a few times the car will start up almost instantaneously. What would i have to change to get this slight problem fixed. The starter motor and spark plugs have recently been changed within the last month. Also, this will only happen after the car has been left to sit for a while. if i turn on the car and turn it back on within 15 minutes the car will start up straight away.
    thanks in advance
    vs commodore
    Oct 2009
    Tamworth NSW
    Check to see if it blows black smoke when it first fires up after not starting. If it does, its probably got leaking fuel injector(s) or a stuffed fuel pressure regulator. When the fuel pressure regulator stuffs up, it lets fuel flow straight into the inlet manifold through the regulator vacuum hose, causing the hard starting etc. Id also check the air filter, and if its old, replace it. Same with the fuel filter. If the injectors turn out to be the problem, the link below shows a set of brand new injectors available on ebay. Ive been running these injectors in my VSV6 for 8 months now, and theyre still going good. They are way cheaper than brand new bosch brand injectors, and they dont hurt performance at all. Remanufactured/reconditioned injectors will never flow as good as brand new ones do anyway, all these injector reco places do is match them up so the set of injectors all flow within 1 or 2% of eachother, but as I said before, they wont flow as good as brand new ones, I was told all this by a couple of EFI places when I was looking into getting my injectors recoed. This is why I went with the brand new ones in the link. Ive also noticed after helping mates fit reco injetcors, that the reco ones dont make much noticable difference to how the car runs etc.
    HOLDEN COMMODORE NEW FUEL INJECTORS VN VP VR VS VT VX VU VY 6 CYL ALL MODELS | eBay
    vs calais s2
    Oct 2011
    Baulkham Hills
    just went out to check, doesn't seem to be any black smoke coming from the back of the car.
    de_overfiend's Avatar
    de_overfiend is offline Beef is Good
    VS Calias
    Aug 2008
    Tweed Heads
    vs calais s2
    Oct 2011
    Baulkham Hills
    vs calais s2
    Oct 2011
    Baulkham Hills
    just have a bit of an update
    tried to start the car up this morning, turned the keys from on to off about 4-5 times tried to start the car, the car kept cranking but seemed like it was trying to start but it
    couldn't, tried cranking again and it did the same thing then on the third attempt started straight away, you guys got an clues to what is going on? is it still possible to be the fuel regulator?
    VR Calais
    Mar 2011
    Plumpton
    U sure the fuel pump hasn't started to give way? I just had the same issue my self n it turns out it was the pump in the tank
    1993 VR CALAIS 5 SPEED MANUAL,Lowered all around on pedders, 20 inch G8s, Option audio front splits, option audio amps, sound stream subs, pace maker extractors, high flow cat, 2.5inch lukey cat back exhaust
    vs calais s2
    Oct 2011
    Baulkham Hills
    mate im honestly not 100% sure, is there any specific way to check if your fuel pump is on the way out?
    VR Calais
    Mar 2011
    Plumpton
    I think they can do a pressure test, but I could be wrong
    vs calais s2
    Oct 2011
    Baulkham Hills
    another update.
    everyday the car seemed to be getting harder and harder to kick over, only when first starting it up after leaving it for a while. but i tried to start it up today and it just wont kick over. it will keep cranking for as long as it wants but it just wont kick. any recommendations?
    vs calais s2
    Oct 2011
    Baulkham Hills
    got the nrma to come check it out, might aswell since its currently free for me, they check the fuel pump relay with a multimeter reading came abck as 1.6, the bloke says it should be up somewhere around 4. says im gonna need to get a mechanic to replace the fuel pump. how much would i expect to pay for installation?
    VP Executive Wagon
    Sep 2011
    Wollongong, NSW
    mate the pump itself is around $200 so with labour you could be looking at $500 plus, but if your a keen DIYer it can be done in around an hour with a few simple tools and a bit of patience
    vs calais s2
    Oct 2011
    Baulkham Hills
    VB SL/E
    Dec 2008
  15. #15
    hako is online now Donating Member
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Steer clear of Goss fuel pumps as many on this forum have had probs with them....someone said Bosch was the go.
  16. #16
    vs calais s2
    Oct 2011
    Baulkham Hills
    thanks for the info guys. Do you actually reckon labour would be $300+ if it is said that is able to be done in under an hour at home? im asking this because i dont have the mechanical knowledge on how to change a fuel pump.
  17. #17
    VB SL/E
    Dec 2008
    Ring around and get a few quotes if you are not mechanically savy, I've done a few myself, easy job essentially but a PITA fitting the actual sender unit back into the tank.
    If you would like to see do a search on fitting a pump.
  18. #18
    VP Executive Wagon
    Sep 2011
    Wollongong, NSW
  19. #19
    VR Calais
    Mar 2011
    Plumpton
    Mate I just did a fuel pump in my vs commy, if u Want me n a couple of mates could do it as a cash job for a fraction of what other places are charging, if your interested pm me
  20. #20
    VS_Pete_1's Avatar
    VS_Pete_1 is online now Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    SUSVS did you do all the hoses on top.
    I got all mine done as sometimes some can be broken.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
  21. #21
    VR Calais
    Mar 2011
    Plumpton
    Na nothing broke while I was doing it, I had no complications
  22. #22
    VRCALAISS is offline Banned
    94 VR CALAIS 3.8L V6
    Jan 2011
    Morayfield,QLD
    Quote Originally Posted by SUSVS View Post
    Does it throw a code?
    Sent from my U8510 using Tapatalk
  23. #23
    VR V6 manny' wagoon
    Jan 2011
    My suggestion is that if you are not confident you can do work on a car, get a mechanic to do it, it might be cheaper in the long run!
    Alternatively, buy a workshop manual. Hell, buy two.
  24. #24
    GENESIS BLUE VR COMMODORE
    May 2011
    Gippsland, Victoria, Australia
    hey guys
    im going to jump in on this as i was just about to put up this topic till i seen this
    my vr has sat for 12months and gone to start and its a B***H to start once its kicked over it runs ruff and idles like crap ive just changed the fuel pump and filter and injector cleaner through it and it still is a pain to start
    starter motor and alternator is fine all fuses fine but yea i thought it was a fuel issue but she blows smoke its a auto but yea i agree with the presure regualtor or the fuel injectors stuffed after seeing the replys thats my next step of attack but your not alone on this and new fuel pump from recpo's is 95bucks and you can do it your self but try a new pump and filter and injector cleaner that helped for 10min anyway lol but then yea youd be up for new fuel injectors and presure regualr possibley
    This Isnt A Site To Talk About Your Relentionship Problems Its A Car Forum
  25. #25
    vs calais s2
    Oct 2011
    Baulkham Hills
    took it down to a mechanics today, it ended up being the fuel pump, cost me 300 all together. thanks for all the help.
  1. Another Problem :( Still Won't Start...
    By Kierab in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-12-2011, 11:29 AM
  2. VL Problem! Won't start..
    By RobboVl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-04-2011, 12:18 PM
  3. Car start problem
    By CHARGEDVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-10-2007, 09:12 PM
  4. Lpg start problem
    By fullymetal in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-04-2007, 12:32 PM
  5. vr.start problem
    By deckadi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-01-2007, 09:30 PM
