Results 1 to 17 of 17
Thread: VS tensioner arm alignment
    VS BT1 V6
    Nov 2004
    Default VS tensioner arm alignment
    My tensioner pulley is out of alignment , is there any way to correct this ?
    Its running on the inside of the belt , [ towards engine ] with about 20% of the belt running of the pulley [ towards radiator ]
    Looks like the tensioner arm is out of alignment ...
    Is there a easy fix ?
    Or do I need a new tensioner arm pulley assembly
    95VS V6 BT1 - CAI - K&N airfilter - Lukey Headers - REdback system - FIT Rockers - PowerChip Gold 98..
    VS V6 Acclaim
    Jul 2008
    They are not adjustable.
    If it looks knackered, out of tension range, you need a new one.
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Sounds like the bearing has collapsed causing the pulley to run crooked. Take the belt off and see if you can move the pulley.
    Visit my Facebook page
    VS BT1 V6
    Nov 2004
    Default Yes
    There is some movement in the pulley arm .. [ In and Out ]
    The pulley itself , seems tight and solid
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Maybe the tensioner itself has collapsed. Time for a new one then.
    VS BT1 V6
    Nov 2004
    Default Hmmm
    How hard would it be to DIY ... ?
    Any instructions , somewhere ?
    hako is online now Donating Member
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You really should buy a workshop manual - Gregorys is about the best. If push comes to shove, pm me your Email address and I'll scan and send the page to you.
    VS BT1 V6
    Nov 2004
    The last couple of years the VS has been relatively trouble free .. As I learn how to deal with it ...
    I kept killing crank angle sensors , till I learned they were sensitive to temperature .. Dont let the engine get hot in warm weather [ if the thermo cuts in , its too hot and you can kill the crank sensor ]
    So I run the air to keep the engine temp down [ cheaper than replacing crank sensors ]
    Yeah , I might have to buy a workshop manual , cars getting long in the tooth , and I sense work will be needed ...
    Last thing I replaced was the water pump .. [ Who ever designed this engine - needs a slap ]
    Did have VS Berlina now have VT Berlina
    Mar 2010
    Cockatoo Vic
    You could do it in an hour with just the simple tools it's pretty easy to do
    VS BT1 V6
    Nov 2004
    I will try and find some instructions on the net :
    It has some strange cover on it : [ The arm ] I thought it might need a special tool ? Havent taken a super close look yet ..
    Been busy being a mature aged student : Now that schools over , need to do some fixin
    Mar 2010
    Cockatoo Vic
    Nah no special tools just need some spanners and or sockets and a couple of screw drivers i would go out and make a video on it but i got rid of my VS the other day
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Just pm me your email address and I will scan the page for you as I suggested in post #7 .....no need to search in the web. There is no obligation - you'll find plenty of help on this forum.
    VS BT1 V6
    Nov 2004
    Default Ok
    Ok , so to remove :
    Get the belt off , remove pulley [ To undo = clockwise I think ]
    The tensioner arm , is that a cover on it ? So stick a screwdriver in there and pop it of ?????
    And the the bolt nut comes out clock ? anti ? wise ... [ the threads might clue me if there visible ]
    How hard is it to change passenger side air bag cover ?
    Thanks guys
    Email = old4570 at yahoo.com
    vs commodore
    Oct 2009
    Tamworth NSW
    If that above picture is of an ecotec V6 tensioner pulley etc, then the belt isnt even fitted properly.Thats probably why you are having problems with the tensioner and the belt alignment. Its supposed to go around the tensioner pulley,then down around the power steering pump pulley, then up around over the alternator pulley.
    Edit: Heres a diagram of how the serpentine belt fits the ecotec engine .You need to get yourself a gregorys workshop manual.
  15. #15
    VS BT1 V6
    Nov 2004
    Default Ok
    Changed it ,, Runs more true now ...
    But I think the belt is a little short .. Tensioner is all the way back , no more play , with help I was just able to slip the belt in place ...
    Is that normal ? [ Must have taken the path of least resistance in the past ] ..
    Thank you ...
    Now that sun warped Airbag cover ? How do I change that ?
  16. #16
    VS V6 Acclaim
    Jul 2008
    OMG. No way.
    Next time, use a breaker bar with a 15mm to turn the tensioner bearing bolt anti-clockwise to preload the tensioner and allow the belt to slip on easily.
    Now have a look at the front of the tensioner and make sure the indicator mark is within the suggested range of movement.
    As for the airbag, i can't help there as i'm laughing to much.
  17. #17
    VS BT1 V6
    Nov 2004
    Default Naaa
    Use a spanner to pre load , or push down tensioner all the way till it stops ...
    There is no more movement left , belt only just slips on and thats with some one else holding the tensioner down ...
    So its supposedly a VS belt but , seems a bits short ,,
    Probably why it was the other way , fits easier , and one person can fit the belt ..
    And if mem serves , this belt was supplied/fitted by the Holden dealer in Oakleigh last time my crank sensor died ...
    Funny , maybe ?
    I may still need to replace the tensioner ...
  1. 4 wheel alignment
    By pikey in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-11-2009, 12:06 AM
  2. Wheel Alignment
    By gunk81 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-09-2009, 03:57 PM
  3. wheel alignment
    By VTvoodoo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-07-2008, 08:00 PM
  4. Wheel Alignment
    By Shounak in forum General
    Last Post: 29-10-2006, 06:55 PM
