Just wondering why Im getting an error code 12 (system check ok) then it spits out error codes 35, 36, 45, 46 ?
Im aware I need to fix the other faults but is error code 12 only popping up when the check has started and finished?
[Error Codes] >>>> Just Commodores - For All Your Holden Commodore Needs
Because it always starts and finishes with code 12, regardless of whether there are fault codes or not.
MY RIDE
Ok cheers, thought that was the case...
