Results 1 to 12 of 12
Thread: Who knows?
    VS Berlina/ KJ Verada
    Sep 2006
    Default Who knows?
    Occasionally when I start my car it will crank a couple of times and just stop for a few seconds and nothing then it will crank again and start... Is the CAS on its way out? Any thoughts appreciated.
    95 VS Berlina
    http://forums.justcommodores.com.au/...ml#post1891856
    I need some statesman/ calais woodgrain for drivers side panel!!
    Snap-on's Avatar
    Snap-on is offline Boilermongrelin
    82 VH, 99 VT Wags, 03 VY S
    Apr 2008
    Brisbane, Northside
    perfectly normal for the ecotec. It will happen more when hot. It's the starter motor. When it gets hot it just turns over slower. Ive got extractors so it makes it even worse - but no problems
    VT Ballin'
    VS_Pete_1's Avatar
    VS_Pete_1 is online now Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    How old is the battery?
    Clean all contacts.
    Check for codes.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    VS_Pete_1's Avatar
    Dec 2007
    Sorry wrong thread
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Had the same problem. It turned out to be the connection on the solenoid was bad and cannot be repiared. It is either replace the starter motor or the solenoid....
    Sep 2006
    Ah ok then. Was it expensive to fix? Never had to replace a starter motor... not a big problem, just annoys me a bit. Cheers guys
    95 VS Berlina
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    That happens to my VS now and then (happened more when I had the ecotec fitted). I think it is normal as well.
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    VB SL/E
    Dec 2008
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by SWE11L View Post
    I had a spare that was meant for a manual, but it does work.
    I would say it is not normal, you can easily check the connection that is bolted to the starter. If it is loose then there is your problem.
    On mine the nut had welded itself on the thread and I had to rip it out to remove it, no doubt this happened because it was getting really hot due to shorting out.
    New starter motors can cost around $200 I did see one on eBay for $99
    http://www.ebay.com.au/itm/NEW-HOLDE...item19cb18140e
    1996 Holden VS Berlina Series II
    Jan 2011
    Mine does this usually if I don't start it up for a while.
    It wouldn't be anything to do with the CAS because it was doing it before with my faulty CAS and still does with a brand new one.
    VR Statesman, WK Statesman
    Aug 2006
    I've heard stories about the engine not being earthed to the chassis very well - I seem to recall one story where the cable that was earthing the engine block actually starting to burn the insulation due to arcing etc.
    Check that one, might need a heavy duty cable from the block to the chassis??
    Sep 2006
    where is the engine earth cable?
    95 VS Berlina
