Question for the guys that actually have a good idea about turbo setups.
I am about to purchase some bosch 968 440cc injectors, the guy im getting them from said to check if I should get bigger for my power gains.
It will be running from 8-12psi depending on circumstances and hopefully producing upto 250rwkw.
What's the verdict?
Thanks in advance
CHECK OUT MY RIDE
http://forums.justcommodores.com.au/member.php?u=62088
LS1 injectors will be fine if you can grab a set...
42lb 968's would be perfect in my opinion. If anything though you're probably better to go a little bigger than necessary to allow for any possible future gains. The duty cycle is just wound down in the tuning.
Z' Series HSV 297KW 6lt LS2 Conversion For Sale!PM Me For Details
Yeah i'm thinking I may as well go a bit bigger so theres more fuel there if I need. Thanks guys
CHECK OUT MY RIDE
Stock 36lb L67 injectors are fine for that boost, but go the 42's for headroom as above.
