Results 1 to 3 of 3
Thread: replacing front studs
    elmaso's Avatar
    elmaso is offline PARTY AND BULLSHIT!
    VR Calais
    Jul 2010
    Default replacing front studs
    just wanted to be pointed in the right direction here, i was told to heat up the studs and hammer them into the hub (front left) then once its on the car chuck the nuts on and give them a good tighten, have i missed anything there?
    cheers
    VZ Wagon
    Jun 2011
    Brisbane North
    Never heated studs in my life, no point, fit them cold.
    If they are standard nuts just use the nut on backwards to pull them in, if not, get some standard nuts and if necessary use a larger nut and maybe washer as a spacer.
    hako is online now Donating Member
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Heating the studs would cause them to expand and make them harder to instal - rambunctious is correct.
  1. Head studs???? and main studs
    By vtv6 in forum V6 Development And Modification
    Last Post: 12-06-2011, 06:49 PM
  2. VX Commodore Front Wheel Studs Compliments of BJT
    By Thorby in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-05-2011, 09:10 PM
  3. Replacing VT front seats
    By FilthyRich in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-05-2010, 03:20 PM
  4. replacing vz front speakers
    By keewee74 in forum Car Audio
    Last Post: 12-01-2009, 05:53 AM
  5. Replacing Front Struts
    By VL-Cruiser in forum VL Holden Commodore (1986 - 1988)
    Last Post: 16-04-2008, 10:51 AM
