hey guys
i put a stereo in and the central locking doesnt work before i put it in it didnt work when i pressed the button the interior light just went on and off and i thought it was the fuse so i replaced the fuse and installed the stereo and it still doesnt work when i had the old stereo in the car it worked fine but now i put the new one in it doesnt work just turns the light on and off
whats the go i got a vr commodore has anyone else had this issue?
cheers
Sounds like maybe your grounding through a wire that's controlling the central locking. Try reg rounding heady to bare metal. Failing that, run a new constant power wire to it.
well i rember i hit the wiring together by accident for the stereo and it sparked would that have anything to do with it?
i dare say u've popped another fuse.. check each fuse one by one under the steering column
cheers ill have a look into that
ive checked all and no fuse issue what else could it be?
Tripple check all your fuses! i had the same problem in my vr and vs, when i installed the headunit, some of the wires touched and it blew some fuses, tripple check the fuses with a torch, doesn't hurt to have another look... that's all i can think of unless you've somehow shorted it...
As excale said, check with multimeter, iff all good, ether a wire a wire has broken in the loom or plug, or a relay may has cooked.
Check fuses and then relay, swap out a known working on, say headlights, and test. If nothing yet, pull off a door trim and test to see if you have power at the actuator
you could of fried the body control module... you should always disconnect yuor battery when doin electrical work it would of saved you all this trouble.... if all fuses and relays are working then you've cooked your BCM which means big $$$
If in doubt......FLOOR IT!!!
