Results 1 to 7 of 7
Thread: vs series 2 radiator with oil but no water in trans or motor.
    Jul 2005
    Default vs series 2 radiator with oil but no water in trans or motor.
    Afternoon all.
    maybe someone here can help.
    i have an issue where im losing water, roughly the reservoir gets empty after 3 or 4 weeks. than needs a refill. about 500k's of driving.
    i have a small amount of oil in my radiator, no water in my engine or trans. but as i said im losing water.
    im leaning towards a head gasket as i may have split the gasket between water gallery and cylinder, hence no water in oil but losing water out the exhaust (water injection back yard style lol) though it doesn't explain the oil in the radiator.
    motor runs fine, little miss here and there but i have not done plugs and cap and button for 12 months. so im guessing its needing the ignition side of things serviced.
    has anyone heard of this problem and have a solution before i rip the heads of to cheack the gasket? big job to do just so i can clear my mind on head gasket.
    if it was a radiator split where the trans cooler is than wouldnt oil go in the trans? not sure.
    all help is appreciated.
    cheers
    ricky
    ps: also noticed this thread Oil in vt 5l radiator had head gasket check seem ok !! Help !!
    but theres no conclusion to his issue.
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Jul 2005
    i have thought of that but im only reading ppl having issues with the v6 inlet. not reading anywhere thats talking about the v8 inlet manifold having issues.
    will pull it of tomorrow if i can sort out some gaskets of holden, i get trade at bursons but rob in carrum downs was telling me that the factory holden inlet gaskets are better. so i will ring them in the morning and get some.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You say in part: "(water injection back yard style lol)" .........I've seen water injection units cause some crazy things - a mate of mine had his unit drain into the cylinders overnight and next morning when he went to start the car it started to turn and BANG....bent the conrods due to hydraulic lock. So I'd be looking there first.
    Jul 2005
    i dont have water injection in my car.
    im saying if its a leaking head gasket from the water jacket to the cylinder than thats where my waters going from my radiator. it definatly wont fill the cylinder and cause compression lock.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    In that case, just unscrew all the plugs and see if one or two appear to have different deposits on them - usually it will be fluffy black stuff - that might give you a clue as to whether it is a head gasket problem. You could also be losing coolant from the heater unit under the dash which is a known fault in Commodores...also the heater tap can leak...cracks in radiator side tanks can be impossible to identify sometimes till they leak really bad....water pump leak also can be hard to identify till it's bad....radiator cap may be leaking slightly. Problem is that the coolant evaporates before you notice it.
    By the way, if a head gasket or cracked head is leaking coolant into a cylinder, I wouldn't bet on it not filling the cylinder overnight.
    VS STATESMAN s3
    Dec 2011
    KEYSBOROUGH 3173
    what color does it look like in ta rad, if pink then is rad. it does happen and u dont get it ur gearbox.. mainfold fold is likely too.
  1. Series 1 motor with series 2 radiator, can it work?
    By DAVIDC in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: Today, 01:00 PM
  2. VH Engine, been under water help bringing her back, Trans radiator hose snapped help?
    By mojo_gc in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-03-2011, 11:12 PM
  3. should external trans radiator be inline with radiator compartment
    By ybl8te in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-10-2010, 10:50 AM
  4. Water in oil and leaking trans And vn s1 motor into vp s2
    By v6vpute in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-09-2010, 05:28 PM
  5. VN series II v6 motor and trans rebuilt, SA
    By churnit in forum Parts And Other Items For Sale
    Last Post: 09-09-2006, 03:55 PM
