Results 1 to 8 of 8
Thread: Engine mounts
    VSAccCom Guest
    Default Engine mounts
    hey guys i need to replace my engine mounts, think about doing it next week myself anyone got any tips or better instructions that my hanes manual, thanks guys any help would be appreciated
    rimz81 Guest
    VSAccCom Guest
    hmmm thanks for a quick reply, my manual says all i gota do is remove the through bolts :S whatever the fk that is, ne one else removed them
    VSAccCom Guest
    rimz81 Guest
    VSAccCom Guest
    hmm yeah i know but thing is HOW!!!!, o well tmmrw is gona be fun, i dunno how im gona get pass side off, driver side i sused out a bit looks ok to do for a noob lol
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Drivers side is easy and takes minimal effort as long as you have something to lift the engine up.I made a bracket that took in a few manifold studs to lift engine on each sidefrom above using chain block.Left hand one is difficult due to the air con compressor being directly mounted on alloy bracket that the mount is bolted to and one of the mount studs is hard to get to so you have to take compressor off and move so you can get to the bolts that mount bracket to engine block. Of course you lift engine up before you try to undo the bolts to take the weight off the mounts but watch you dont lift too high and push throttle body into firewall.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    HDT_aero is offline resident bush mechanic
    manual VN aero
    May 2005
    SA
    not true unbolt the drivers side from the block (support engine first!!) then undo the passenger side from underneath lift the engine as far as you can an then unbolt the passenger side from the block. the air compressor doesnt have to move so long as you have a hoist. make sure you put it back in reverse order and no you cant just undo the k frame bolts and pull it up at least one side must be unbolted from the block
  1. VT Engine Mounts
    By Stretcher Bearer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-06-2011, 05:45 PM
  2. engine mounts
    By markovr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-07-2009, 05:28 PM
  3. Engine MountS!!!!
    By Joey_21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2007, 02:43 PM
  4. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
  5. Engine mounts
    By RockyC in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-06-2005, 12:21 PM
