my vs is getting harder to start....it just winds for awhile before it will start. any ideas what could be causing this??
Could be one of a thousand things - to narrow the odds, do an error code check: Checking error codes VR/VS (Revised)
checked for error codes and all i got was 12 which is everything is alright!! i think that error code stuff is a load of....last time i had problems with my car i done error code checks aswel and all i got was 12 but when i took it to my mechanic it ended up costing $1900 to fix everything wrong with my car! my 02 sensors have been changed,my fuel pump+filter,drive belt,tensioner assy,pullys,radiator+heater hoses,thermostat+gasket+o-rings,intake manifold+gasket+endseal,water pump,ignition coil,pressure testing on the motor.
because only one of the coils was faulty and changed could it be that another or the rest of them are failing?
are you letting the codes go more than 3 times? as it will give you 12 3 times, then after that any codes.
Codes are only logged if sensors go out of range, doesn't mean there is nothing wrong.
yeh i let them go 7 times just to be sure and all i got was 12 every time
so when you say winds for a while, only a split second, 3 or more seconds?
some times 5 seconds or more. ive found that if i let it wind 2 or 3 times then stop then turn the key again it will start after about 2 or 3 winds but the revs go upto about 1500rpm for a couple of seconds then back down to normal
so it sounds like it's pumping fuel then, should be able to pull a spark plug out after winding a bit and will probably be wet with fuel, see what your spark plugs are like anyway, post a photo perhaps.
i changed the plugs and leads about 2 months ago and the fuel pump got changed about a month ago but il check the plugs out. wont do it tonight but will probly do it tomorrow and try to post some pics
it happened with my car for a while, i just got a new battery and keys cos they we pretty much gone,
dunno if im being of any help but it fixed the problem for me
Get a multi meter and check your battery. Tell me how you go
I reject your reality and substitute my own.
Comfortablynumb
Did you solve the problem?
