Results 1 to 4 of 4
Thread: vibrations
    vr commodore
    Dec 2011
    cranebrook
    Default vibrations
    my vr auto has a vibration in it ,when i start it ,driving along while i accelerate it almost shakes the car to bits i have checked a majority of stuff under the car
    but i still carnt find the problem i thought it might be the harmonic balance but all it has is a small splits around the center does nt seem to be enough to effect it
    has anyone got any suggestions what it might be.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If the harmonic balancer has splits as you suggest I'd get it replaced soon.....the splits are a warning that it is on it's last legs. The HB will not be causing the vibration.
    Re the vibration, Commodores do vibrate a bit under harsh acceleration and many new owners comment about this. There may be worn components in the drive train which you need to check one by one.
    VR Statesman, WK Statesman
    Aug 2006
    Possibly the bearing in the back of your trans, where the tailshaft goes in. I've seen a few cars shudder under load when these are on their way out.
    vr commodore v8
    Oct 2005
    Melboune
    tail shaft center bearing possibly but it will be more obvious under acceleration or maybe a uni joint in the tail shaft may have seized
  1. bad vibrations
    By gladi in forum General
    Last Post: 23-07-2006, 06:55 PM
  2. Bad Vibrations.
    By 253@7k in forum Car Audio
    Last Post: 14-06-2006, 11:41 PM
  3. Bad Vibrations
    By Spilly in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-02-2005, 12:47 PM
  4. VibrationS!!!
    By Bob129 in forum Car Audio
    Last Post: 29-01-2005, 09:42 PM
  5. Vibrations
    By tr3nt in forum Car Audio
    Last Post: 29-01-2004, 06:54 PM
