Results 1 to 3 of 3
Thread: Rear Wheel Wobble ? VR UTE
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Default Rear Wheel Wobble ? VR UTE
    So I had a bloke pull me over the other day to tell me my back left wheel was on the piss a bit.
    It was wobbling bad enough for him to express his concern so when I made it home I changed the rear rims with some stockies and then a fews days later I get followed home by a bloke on a Motorbike who tells me the same thing is still happening?
    I can not figure out why its bent out of shape, The 20's I had on the rear at first didn't have the inner hub spacer so maybe it was from that? I haven't clipped any gutters so im puzzled as to why its doing it.
    Upon closer inspection I did notice that the gap between the back of the wheel and the drum was wider at one point then gradually got thinner as you followed it around, so clearly its not sitting against the drum evenly...
    Im going to call up a wreckers tomorrow and get a new rear assembly but if I anyone can give me ideas to why its doing it and if it could be fixed it would save me a large amount of coin and id be happy as Larry. (who ever he might be)
    VZ Wagon
    Jun 2011
    Brisbane North
    My thoughts are the rim is not sitting over the raised centre of the axle.
    Remove the rim and measure the axle centre against the measurement of the hole in the centre of the rim, and naturally, if the hole is smaller than the diameter of the axle stub then the problem is wrong wheels.
    93' Pov-Pac
    Jul 2010
    Is the brake disc not on properly? It sounds like something may be up with the axle, and/or the studs. If you can, pull it out and have a look ,see if anything is bent. If so, i'd replace that part.
  1. Vs wheel wobble
    By ab56452001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2011, 07:56 PM
  2. VX equipe wheel wobble
    By c2105026 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-05-2011, 11:28 PM
  3. Steering wheel wobble
    By OldDog in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-06-2010, 07:46 PM
  4. Wheel Wobble
    By boobotam in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-01-2010, 11:16 AM
  5. steering wheel wobble
    By VTPREDATOR in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-11-2008, 09:31 PM
