Results 1 to 9 of 9
Thread: water inside boot lid
    pando666 is offline milk comes in 2 litres
    vs exec
    Jul 2008
    sydney
    Default water inside boot lid
    Where the hell does the water in my boot lid come from I've sealed all the lights and trim etc but it still gets in. Does anyone know how to fix/solve this problem?.
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    WL Caprice
    Mar 2011
    Look around the seal on the lid. If there is any moisture that may be a clue.
    Has it been repaired (accident) or has it got perished seals?
    How much water? A drop or an ocean?
    VS Executive Wagon
    Oct 2009
    I had this problem with my VR, i found it was leaking around the rear quarter window. i removed the rubber exterior seal around the window, and the small exterior panel between the window and boot. pour water over top of quarter window towards boot, check to see if visible in boot if so reseal and asemble. it took me weeks to find it...
    VZ Wagon
    Jun 2011
    Brisbane North
    Don't know if this is similar but years ago I had a problem with a VL sedan.
    I found the rear windscreen was leaking into the parcel shelf then down through the seat belt hole into the boot.
    Sealed the windscreen and no more water in boot.
    1997 VS Berlina
    Apr 2011
    South Sydney
    get a new rubber seal around the boot cuz they can get squashed over time and water flows over the top. thats why mine was leaking and when i say leaking it was alot of water haha also see if you have any rust around or on the bootlid cuz thats also a way that it gets in
    vs exec
    Jul 2008
    sydney
    Quote Originally Posted by CapriciousWL View Post
    Bucket loads of water pisses through the two holes at each end when you open the boot and naturally then soaks the carpet. No accident seal is not perished.
    vs exec
    Jul 2008
    sydney
    Quote Originally Posted by CJ - 1995 View Post
    I think your right seal looks a little squashed. as for rust it didnt have any but now due to the leak I think I'm due a new boot lid
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If you have a wing on the boot they will leak where the wiring goes thru and also at mounting points - also when the boot lids is up, have a look inside the lid where the rear garnishes are attached - they can and will come loose - we had this same problem with buckets of water showering you when opening the boot and it turned out to be the garnish mounting points. Basically you need to apply sikaflex to everything you can see... make sure it's clean first.
  1. water leak inside front driver and passenger seat.
    By vtca in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-04-2011, 01:20 PM
  2. vrvs sedan water found in boot how i tested to find where the water was leaking from
    By peter1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-01-2011, 08:49 PM
  3. VP Air Con dumping water inside cabin
    By Crow32 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-12-2010, 11:33 AM
  4. Leaking water inside cabin
    By python_hunter1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-07-2009, 09:55 PM
  5. Water leak inside cabin...
    By MY_95_VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-08-2008, 05:21 PM
