Results 1 to 2 of 2
Thread: help with aftermarket gauges
    vr
    Jul 2011
    adelaide
    Default help with aftermarket gauges
    Im looking at getting some gauges for my 94 3.8 vr but just need to know the normal running range of the water temp, oil temp and oil pressure in bar format. so i can buy the right range gauges.
    these are the gauges im looking at getting
    2" Electrical Oil Pressure Gauge (Pressure gauge reads from 0 to 7 Bar (0 to 100 Psi))
    2" Electrical Oil Temperature Gauge (Temperature gauge reads from 50 to 150 Degrees Celsius)
    2" Electrical Water Temperature Gauge (Temperature gauge reads from 40 to 120 Degrees Celsius)
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Don't know about oil temp, but coolant temp will sit just under 100 degrees c. Like 95-98.
    Pressure will be between 40-60 PSI.
  1. Wiring Up Aftermarket Gauges, Anyone Want To Help?
    By tim005 in forum Electrical Wiring / Questions
    Last Post: 02-07-2011, 03:14 PM
  2. [VIC] wtb vs wagon aftermarket exhaust, passenger side exstractors, aftermarket seats.
    By commocars in forum Swap / Wanted to Buy / Trade
    Last Post: 06-03-2011, 10:35 PM
  3. Installing Aftermarket Tacho / Voltage Gauges - VZ Exec - HELP
    By bigdaddycool in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-07-2009, 07:44 PM
  4. Mounting aftermarket gauges in VN
    By crazybiker in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-11-2008, 05:35 PM
  5. aftermarket gauges
    By stocky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-11-2006, 07:36 PM
