hi, my vs is getting hard to start first thing in the morning or late at night after been sitting for say 6 or more hours (night work), it cranks over for about 3 seconds then fires but when hot it starts first time but when cold and it starts can smells fuel smell and soetimes if in an enclosed arear like a drive through at maccas etc it has a slight smell to. i took the vacum line off teh regulator and there was some oily sludg in there when i put my finger over the vacum inlet on the regulator. also caoul smell a strong fuel smell mixed in witth the oily stuff and the hose smelt a it like fuel
anyway is the regulator stuffed? injectors have been replaced although some orings are leaking i will be fixing tha in a few days but it was doing this even before i put different injectors in
cheers
sounds like your reg is leaking fuel into the manifold thru the vac line and the black sludge will be the perished rubber , replace the reg and your troubles should be gone along with improve fuel economy and better starting
"Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
My VS II Berlina Wagon
MY12 II SV6 Sportwagon
