Hi Peoples
Have a problem with my VR SS V8 5hdd tranny it doesnt want to shift past 2nd gear.I read that the 3-4 solenoid can be dead and thus need to be replaced but not sure so I replaced the whole transmission with another one with same-ish km's and within 5 months the exact same problem has happened wondering if anyone had any helpful words with past experiences or so on
PS: also can you change trannys from a 5hdd to 6hdd or 7hdd
I think your trans should be a 5HBD so if you have a 5HDD then that is the trans for the V6.....V8 tran are HBD. Apart from that, you should use the same model/year box that came with that car especially with VR as the VS boxes have an extra pin in the electrical connection and will not work correctly in a VR.(this is for the V6 so I presume same for V8).
Do a fault code check which will tell you if there is a solenoid fault although your fault sounds more like a bad TPS (throttle position sensor).
Checking error codes VR/VS (Revised)
I hope they interchange. I have a Auto Transmission out of a VY Calais in My VS at the moment....
Originally Posted by Jasper44
Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
This is a handy guide to different applications:
http://www.acdelco.com.au/PDFs/Catal...nsmissions.pdf
Ah thanks for that hako
I'll double check what model my Transmission is when I lift it on the hoist and see if its ok or not.
I had a look at the code on the VS and VY Transmissions but I think I should be going off the VS code because it has a VS wiring loom.
So it needs to be a 7HLD but its either got a 3HND or 4HND. Wish they didn't paint over the sticker when it was reconditioned at some stage.
