Results 1 to 5 of 5
Thread: Weird beeping???
    VZ SV6 Manual
    Sep 2010
    Default Weird beeping???
    Hey all
    After replacing my oxy sensors, (not sure if it's a coincidence)
    But when I drive along it keeps beeping!!! Its a similar beep to when it's over heated but I've triple checked and it's not that
    I've checked error codes and it comes up with 33??? And on the list there is no such thing!!
    Its driving me fkn crazy...... Help!!!
    Btw it's a vs Calais
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If your Calais is a V8 it is: Code 33 - MAP Sensor Signal - Voltage Too High
    I'd also recheck the connections to the sensors.
    VZ SV6 Manual
    Sep 2010
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Forget the code 33 - reset the ECU and it probably will never come back. Re the beep.....are any warning lights on like brakes etc?....the beep 'should' be accompanied by a warning light....not your speed alert set very low?
    VZ SV6 Manual
    Sep 2010
    The air bag light is on but it has been on since I got the car I'll try the ecu and see what happends
    Thanks mate
  1. weird loud beeping noise.....
    By dezzavy in forum Car Audio
    Last Post: 31-01-2011, 08:19 PM
  2. VE SS-V beeping at start-up
    By woodys90 in forum VE Holden Commodore (2006 - ?)
    Last Post: 02-02-2010, 02:32 AM
  3. beeping in the cluster
    By slipstream001 in forum Electrical Wiring / Questions
    Last Post: 16-11-2007, 02:57 PM
  4. Stupid Beeping!!
    By frenzal_tom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-11-2007, 03:05 PM
  5. vl beeping?
    By sully in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-03-2005, 03:15 PM
