Does anyone know the average price to put in electric windows to a 97 vs?
How longs a piece of string?
Do u want genuine or aftermarket, new or secondhand, bcm integrated or standalone?
If u surf eBay, u can get the secondhand gen units for 200, add the fuses and relays and ur just about done. What model is ur car exec or acclaim?
That's why i said the average price, not something to cheap and tacky but not something thats going to burn a hole in my pocket.
It's a 1997 VS Acclaim
Vs acclaim, like mine should have the wiring half there. Check for contacts in fuse no 5 and contacts in the power window spot.
If u've got em, the most expensive part is the window regs
How deep are ur pockets? As in what's roughly ur budget?
i did it to my old vr acclaim a few years ago, you'll need
: regs
: switches
: circuit breaker (goes in fuse panel instead of fuse)
: 2 relays next to fuse panel under dash
: wiring from B pillar into back doors
i paid
4 doors with power window regs off ebay $70
got switches with a vs calais interior i put into the vr also but one centre switch was stuffed so bought another from the wreckers $30
"borrowed" circuit breaker from wreckers
had relays laying around (4 and 5 pin i think)
got rear door wiring from wreckers free
id say if you look around you could probably get away with it for $100-$150, for example i found 2 complete doors on ebay (after id bought the other 4 a few weeks earlier and stuffed one of the back ones) for $10 each and the regs were fine,one of them is in my ss now.
it will probably take a few hours to do and can be a pain in the arse (from what i can remember the front door windows had to come out) but its not overly hard
