Results 1 to 5 of 5
Thread: VS 5ltr
    VS Commodore Ute 5.0
    Dec 2011
    Darwin
    Default VS 5ltr
    Holden commodore ute 5ltr 2000.
    Hey i am currently having firing problems. Car will run fine for a few minutes then cut out. am getting fuel up at the rail. Will cut out when driving but will roll start again a couple of times then will just cut out completely. No blown fuses and have just replaced the fuel filter incase of a blockage. Went to start again just before and had spark. Change of ignition module made no difference. Just replaced coil 1000kms ago. Any ideas on what i could check next?
    VS 5 Litre BT1
    Jul 2006
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Dec 2011
    Darwin
    any reason why it would be the fuel pump? I just finished cleaning out the dizzy cap and rotor button and i'm still having the same problem? And na i haven't checked the codes manually yet.
    vr commodore 355ci
    Nov 2011
    Gold Coast
    check the plug that runs into the side of the distributor has a good connection
  1. VT 5ltr C12 pin
    By GTS308 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-11-2010, 01:50 AM
  2. wtb: 5ltr v8 sa
    By LUMPY 8 in forum Swap / Wanted to Buy / Trade
    Last Post: 11-08-2008, 10:54 PM
  3. my vs 5ltr what do you think
    By vs blown in forum VR - VS
    Last Post: 11-09-2007, 11:34 PM
  4. my vt 5ltr
    By GEEUUP in forum VT - VX - VU - WH - V2
    Last Post: 21-07-2006, 11:46 AM
