Results 1 to 3 of 3
Thread: Will a vs ss fuel tank fit a vr s2 irs
    94 vr acclaim
    Mar 2011
    ehab halabi
    Default Will a vs ss fuel tank fit a vr s2 irs
    Hey guys was wondering if a vs ss fuel tank that came out of an irs fir my vr s2 irs,the guy has straps and sender unit for good price and the tank is 73 ltrs,any help would be appreciated,thanks heaps folks
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    yep, straight swap as far as fitment goes.
    only prob is that the plug/s for pump and sender unit are different. the VS uses a single plug, while the VR uses two plugs (one for pump, one for sender).
    so you'll need the correct plug from a wreckers etc, and change it over.
    94 vr acclaim
    Mar 2011
    ehab halabi
    hey the guy with the tank has the vr sender unit will this make it any easier to swap over the tanks.
  1. Replaced standard fuel tank with long range tank..Now car keeps cutting out
    By bj42turbo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-04-2011, 09:57 PM
  2. 1998 vs statesman v6, 80l Fuel Tank into VN V6 with standard tank
    Last Post: 19-03-2011, 07:30 PM
  3. vs fuel tank sender unit to vk fuel gauge
    By joe65 in forum Electrical Wiring / Questions
    Last Post: 11-09-2010, 02:08 PM
  4. have had to wack the fuel tank to start my car!! is my fuel pump stuffed?
    By CV6Z in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2010, 04:13 PM
  5. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
