Results 1 to 8 of 8
Thread: big problem all of a sudden
    05 vz ss
    Oct 2010
    brisbane
    Default big problem all of a sudden
    gday all im come across i bit of problem . unsure what is the cause but i went todo a compression test on vs (vt engine) all went well i took the fuel pump fuse out and started the car to remove any fuel from the engine and i took all the leads of at the coil pack end and i did the compression test with the spark plugs in at one at a time so i took one out and when i was finshed with that cylinder i put it back in . all cylinders were with in 185psi to 200psi . so i put everthing back together started her up and all it does it shutter and spit now and idles about 1200rpm and just doesnt fill right i though mite be leads check them made sure there all in order all good check the spark plugs little bit dodgy so went a bought some new ones put them in still buggered . i tryed swapping coil packs around with ones i had spare still no change so i decided to take the spark pllugs back out to inspect them and 4 seem to have a little white powder colour on them and the other to look like there brand new . but those to that look good i traced them back to the same coil pack ?????? is there anything i may have stuffed up or missed and help would greatly appreciated as its an only car i have and needs to get goin cheers
    05 vz ss
    Oct 2010
    brisbane
    i went back and had a look at the spark and notice im not getting any spark on one coil pack . so i switched them over with a spare coil pack i had put it on and there is still no spark comin from that one ????? any idea could it be a shit dfi module
    VS_Pete_1's Avatar
    VS_Pete_1 is online now Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    The cars are getting old DFI I think.
    Where are u?
    Me Newmarket.
    I have a DFI module but the bolt broke off and is still in it.
    If you think u can get it out it`s yours.
    They are dear.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    05 vz ss
    Oct 2010
    brisbane
    cheers mate im in capalaba but i think im gonna head down to abc wreckers tommorrow an pinch one . so you recon dfi mate
    VS_Pete_1's Avatar
    Dec 2007
    No that`s my old one I put a new one in mine with new coils and wiring was very dear.
    The_Doctor is offline Banned
    VE SSV Series 2 Redline
    Sep 2011
    Did you replace the fuel pump fuse? Again, push it onto the road and call the RACV or RAA or whoever it is in your state, they will tell you whats wrong without you getting your hands dirty.
    Dec 2009
    Have you checked all of the spark plug leads to make sure they are all within spec (maximum resistance) or if any have become open circuited? I'd be checking everthing you removed in the first instance for example you may have damaged a lead removing it.
    05 vz ss
    Oct 2010
    brisbane
    when i took the leads off dumb a*s me took them off at the coil pack end so that all the coil packs where opened to circuit each other everytime i crank it over to do the compress test ???? could that be the problemm ???????
  1. Sudden Missfire VS V6
    By JoshSvc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-02-2011, 05:12 PM
  2. VS V6 ticking all of a sudden
    By sydsider66 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-10-2009, 01:38 PM
  3. Sudden Suprise
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-11-2005, 08:52 PM
  4. Sudden Suprise!
    By HoZy in forum Jokes/Humour
    Last Post: 13-10-2005, 05:55 PM
  5. sudden overheating
    By spice_man2069 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-08-2005, 11:15 AM
