Results 1 to 11 of 11
Thread: Gasket in Wrong way?
    Drawnnite's Avatar
    Drawnnite is online now Obviously Unsensible
    2000 Vs Ute
    Sep 2010
    Default Gasket in Wrong way?
    quick question before i have to go out and fiddle around more.
    if i put the gasket in the rocker covers the wrong way around (so the tab doesnt go into the tab spot) would it be detremental to the motor?
    eg. could it cause leaks?
    ill probably still turn it around anyway.
    but would it do any harm if i drove it say up to 10kms?
    thanks in advance.
    how about we make the pedals out of sticky rubber and the shoes with steel spikes. at least my shins would like that
    Quote Originally Posted by Jonesy484 View Post
    yeah i wondered the same thing when i was 4 when i grabbed the chrome exhaust of my dads rx7
    Quote Originally Posted by DM 55 WA View Post
    did you think it was a milo tin?
    EVIL304
    Oct 2011
    I would run the car for a couple of mins and see how bad the leak is and take it from there.But ideally take mum or dads car down to get some new gaskets if there stuffed.Try and turn them around first while the engine is still cold did you use any gasket sealant?
    Zeussy's Avatar
    Zeussy is offline SSM11K
    VY Acclaim S2, VH SLE
    Dec 2008
    Central Coast
    If its not leaking now, chances are it won't leak, the little tabs aren't what create a seal, they just locate it.
    If you're worried just pull them back off and flip them over/around until the tabs line up. Even throw on some gasket maker/silicon.
    Drawnnite's Avatar
    2000 Vs Ute
    Sep 2010
    thanks for that quick reply guys.
    i have just put the new rocker covers and gaskets in.
    i didnt think i did the drivers side one right. by not lining the gasket up properly (upside down if that makes sense)
    i was just being lazy =P
    so ill just take it off and make sure it was in properly.
    which ill do when it cools down (outside temp that is)
    thanks again
    EVIL304
    Oct 2011
    Quote Originally Posted by Drawnnite View Post
    thanks again
    Gasket lip should be pointing downwards have fun mate hows ya back feeling
    Drawnnite's Avatar
    2000 Vs Ute
    Sep 2010
    Quote Originally Posted by 5LVTSS View Post
    it felt good.
    its more the hands that hurt.
    getting to the bolts holding the covers in right at the back near the firewall were hard.
    especially the drivers side one =P
    EVIL304
    Oct 2011
    Yes i feel your pain mate and that back bolt gave me the shits aswell ended up dropping it in the engine bay and to make things worse i didn't hear it hit the ground. It got stuck some where in the engine bay so back down to the auto shop i went.
    Drawnnite's Avatar
    2000 Vs Ute
    Sep 2010
    yeah well checking it today i managed to drop a 13mm nut that holds a little bar with the leads on it.
    only drove the car like 20m max (out of garage, and around driveway to back (turn around) car in closer to bench, for more room)
    the bloody exhaust headers (stock mind you) were like bloody fire =P
    found the nut sitting on some crossmember thing.
    then knocked it onto floor =P
    nothing worse then loosing nuts/bolts.
    oh and the gaskets were in right.
    my mind was playing tricks on me.
    also there is a snapped bolt (well more of a thread?) that holds the exhaust headers in place?
    its on the passenger side right up the front.
    it also holds some C shaped bracket that looks like it does nothing =P
    anyone know if this would be a big problem?
    and if it is what can be done about it? =P (if its no problem ill just leave it. as it still is holding the exhaust in?)
    EVIL304
    Oct 2011
    Howdy mate if i have this right the bolt head has snapped off and your left with a thread stuck in the hole.If so i would replace it and any other suspect bolts, you can go to the hardware shop and buy something called easy outs. (just ask for something removes threads) It may be that your loosing power because of a leak in your headers all be it factory headers.The C shaped bracket is prob a heat sheild and if it was me i would put it back on if its not rooted so i hope that helps you bud good luck.
    Drawnnite's Avatar
    2000 Vs Ute
    Sep 2010
    yeah its all back where it goes. as the bolt sheared on a slight angle. so i put it back in its spot.
    yeah we have the easy outs at home... already used them on car parts before =P
    ill have to have a look into it.
    but thanks for the info and help =P
    EVIL304
    Oct 2011
    Not a prob mate
  1. VS - Head gasket or intake gasket?
    By Barto76 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-01-2012, 08:50 PM
  2. Head gasket or inlet manifold gasket? HELP!
    By CUR53VT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-11-2011, 03:54 PM
  3. head gasket or intake manifold gasket? how to tell? bit of assistance
    By Go_Slow in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2011, 04:26 PM
  4. Head Gasket? Inlet Manifold Gasket ? which one ?
    By Hydrobollox in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-04-2010, 08:11 PM
  5. Flange Gasket and Exhaust Manifold Gasket
    By mrvdv85 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-09-2009, 06:46 PM
