Hi guys,
I'm having some cooling issues, when I'm in heavy traffic the engine temperature increases to a touch over half way and then the fan kicks in to keep the temp down a little, but after the fan stops the temperature goes straight back up. I have no problems at highway driving and my coolant levels are fine.
I've read a few posts here which suggests it may be a water pump, in particular the impellers may have deteriorated. My car has 115xxx K's so I figue replacing the water pump might be the go.
Can any one recommend which brand of water pump I should buy? There are numerous choices on ebay etc but not sure which is better than the other.
Cheers,
Andrew
